Im trying to run Timestamps.ino (an example sketch) from the sdfat.h lib into a mkrzero arduino.
This is the code I am running:
* This program tests the dateTimeCallback() function
* and the timestamp() function.
#include <SPI.h>
#include "SdFat114.h"
#include "sdios.h"
SdFat sd;
SdFile file;
// Default SD chip select is SS pin
const uint8_t chipSelect = 28;
// create Serial stream
ArduinoOutStream cout(Serial);
// store error strings in flash to save RAM
#define error(s) sd.errorHalt(F(s))
- date/time values for debug
- normally supplied by a real-time clock or GPS
// date 1-Oct-14
uint16_t year = 2014;
uint8_t month = 10;
uint8_t day = 1;
// time 20:30:40
uint8_t hour = 20;
uint8_t minute = 30;
uint8_t second = 40;
- User provided date time callback function.
- See SdFile::dateTimeCallback() for usage.
void dateTime(uint16_t date, uint16_t* time) {
// User gets date and time from GPS or real-time
// clock in real callback function
// return date using FAT_DATE macro to format fields
*date = FAT_DATE(year, month, day);
// return time using FAT_TIME macro to format fields
time = FAT_TIME(hour, minute, second);
- Function to print all timestamps.
void printTimestamps(SdFile& f) {
dir_t d;
if (!f.dirEntry(&d)) {
error("f.dirEntry failed");
cout << F("Creation: ");
f.printFatDate(d.creationDate);
cout << ' ';
f.printFatTime(d.creationTime);
cout << endl;
cout << F("Modify: ");
f.printFatDate(d.lastWriteDate);
cout <<' ';
f.printFatTime(d.lastWriteTime);
cout << endl;
cout << F("Access: ");
f.printFatDate(d.lastAccessDate);
cout << endl;
void setup(void) {
Serial.begin(9600);
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
cout << F("Type any character to start\n");
while (!Serial.available()) {
SysCall::yield();
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.begin(chipSelect, SD_SCK_MHZ(50))) {
sd.initErrorHalt();
// remove files if they exist
sd.remove("callback.txt");
sd.remove("default.txt");
sd.remove("stamp.txt");
// create a new file with default timestamps
if (!file.open("default.txt", O_WRONLY | O_CREAT)) {
error("open default.txt failed");
cout << F("\nOpen with default times\n");
printTimestamps(file);
// close file
file.close();
- Test the date time callback function.
- dateTimeCallback() sets the function
- that is called when a file is created
- or when a file's directory entry is
- modified by sync().
- The callback can be disabled by the call
- SdFile::dateTimeCallbackCancel()
// set date time callback function
SdFile::dateTimeCallback(dateTime);
// create a new file with callback timestamps
if (!file.open("callback.txt", O_WRONLY | O_CREAT)) {
error("open callback.txt failed");
cout << ("\nOpen with callback times\n");
// change call back date
day += 1;
// must add two to see change since FAT second field is 5-bits
second += 2;
// modify file by writing a byte
file.write('t');
// force dir update
file.sync();
cout << F("\nTimes after write\n");
// close file
file.close();
- Test timestamp() function
- Cancel callback so sync will not
- change access/modify timestamp
SdFile::dateTimeCallbackCancel();
if (!file.open("stamp.txt", O_WRONLY | O_CREAT)) {
error("open stamp.txt failed");
// set creation date time
if (!file.timestamp(T_CREATE, 2014, 11, 10, 1, 2, 3)) {
error("set create time failed");
// set write/modification date time
if (!file.timestamp(T_WRITE, 2014, 11, 11, 4, 5, 6)) {
error("set write time failed");
// set access date
if (!file.timestamp(T_ACCESS, 2014, 11, 12, 7, 8, 9)) {
error("set access time failed");
cout << F("\nTimes after timestamp() calls\n");
file.close();
cout << F("\nDone\n");
void loop() {}
And this is the error I get when I press any key into the serial.
Can't access SD card. Do not reformat.
SD errorCode: 0X30,0X2
It's not and sd format problem, and I know that the chipselect pin for the SD is 28.
I have no idea what is wrong. Is it maybe a samd21 limitation with this library? is it there a samd21 lib for sd card?
I have written data in the sd card with other avr so I dont think the sd card is the problem.
Thanks
