I have an Arduino MKR Zero with an UDA1334 I2S module, alongside 2 Speakers and I am trying to play Stereo sound. So far everything seems to work well, connections are also properly done, and i can play wav files. But i also want to be able to play sound either on the right channel only or sometimes only on the left channel. I tried to use audacity to make sounds only on the right channel for example, but when i play the .wav file, i still get the sound on both speakers. How can i fix this please? Is there any syntax to play sound only on the right channel? Thank you.
PS. TestR.wav is a only on the right channel.
#include <SD.h>
#include <ArduinoSound.h>
const char filename[] = "testR.wav"; SDWaveFile waveFile;
void setup() { Serial.begin(9600); while (!Serial){;};
Serial.print("Initializing SD card..."); if (!SD.begin(28)) { Serial.println("SD card initialization failed!"); return; } Serial.println("SD card is valid."); waveFile = SDWaveFile(filename); // create a SDWaveFile // Serial.println(typeof(waveFile)); if (!waveFile) { Serial.println("wave file is invalid!"); while (1); // do nothing }
// print out some info. about the wave file
Serial.print("Bits per sample = "); Serial.println(waveFile.bitsPerSample()); long channels = waveFile.channels(); Serial.print("Channels = "); Serial.println(channels); long sampleRate = waveFile.sampleRate(); Serial.print("Sample rate = "); Serial.print(sampleRate); Serial.println(" Hz"); long duration = waveFile.duration(); Serial.print("Duration = "); Serial.print(duration); Serial.println(" seconds");
AudioOutI2S.volume(100);
if (!AudioOutI2S.canPlay(waveFile)) { Serial.println("unable to play wave file using I2S!"); while (1); // do nothing } Serial.println("starting playback"); AudioOutI2S.play(waveFile); }
void loop() { if (!AudioOutI2S.isPlaying()) { Serial.println("playback stopped"); while (1); } }
Swedgin
  • 241
Mr. Chin
