map() doesn't quite work as you'd expect. The formula is:
(x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
And all those values are long, which is a "long" integer. So all operations are done as integers, and that means that you lose an awful lot of precision in the calculation, since all decimal components are completely ignored.
It means that you only get the maximum output when you put in the maximum input.
As Michael Keijzers notes your expected output is x/16 (or x>>4 in bitwise notation), and that can be achieved with map() if you set the maximum input to be 48, not 63.
However a simple right shift 4 bits (or divide by 16 if the compiler is clever enough to implement it as a right shift) is a more efficient solution by far, since the processing involved is almost negligible, whereas multiplying and dividing is a relatively expensive set of operations.
