I have worked on SPI devices connected with an Arduino one at a time. How do I work with two different SPI devices at the same time?
Asked
Active
Viewed 2.9k times
24
Assuming you just want to connect two SPI slave devices to the SPI bus and use them in a mutually exclusive way under software control, with the Arduino as the master, then you just need to make sure you use a different pin for the slave select (SS) on each SPI device.
When you want to talk to one slave, you hold its SS low and drive the other high. Do the opposite to talk to the other slave.
There are some devils in the detail using multiple slaves, and these are explained in more depth here, but in general, it's quite common and OK to use more than one SPI device as a slave.
This blog post will give you more information and is a good place to start reading.
Roger Rowland
- 600
- 1
- 4
- 8
