I am trying to reach the webserver running in my Wemos D1 Mini compatible board.
I am trying one esp8266 example using Arduino examples "WifiManualServer" code below. I have replaced the SSI and password for my wifi network in the lines
#define STASSID "my wifi ssid"
#define STAPSK "my secret"
This sketch demonstrates how to set up a simple HTTP-like server.
The server will set a GPIO pin depending on the request
http://server_ip/gpio/0 will set the GPIO2 low,
http://server_ip/gpio/1 will set the GPIO2 high
server_ip is the IP address of the ESP8266 module, will be
printed to Serial when the module is connected.
#include <ESP8266WiFi.h>
#ifndef STASSID
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
Serial.begin(115200);
// prepare LED
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, 0);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print(F("Connecting to "));
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
delay(500);
Serial.print(F("."));
Serial.println();
Serial.println(F("WiFi connected"));
// Start the server
server.begin();
Serial.println(F("Server started"));
// Print the IP address
Serial.println(WiFi.localIP());
server = WiFiServer(80);
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
Serial.println(F("new client"));
client.setTimeout(5000); // default is 1000
// Read the first line of the request
String req = client.readStringUntil('\r');
Serial.println(F("request: "));
Serial.println(req);
// Match the request
int val;
if (req.indexOf(F("/gpio/0")) != -1) {
val = 0;
} else if (req.indexOf(F("/gpio/1")) != -1) {
val = 1;
} else {
Serial.println(F("invalid request"));
val = digitalRead(LED_BUILTIN);
// Set LED according to the request
digitalWrite(LED_BUILTIN, val);
// read/ignore the rest of the request
// do not client.flush(): it is for output only, see below
while (client.available()) {
// byte by byte is not very efficient
client.read();
// Send the response to the client
// it is OK for multiple small client.print/write,
// because nagle algorithm will group them into one single packet
client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now "));
client.print((val) ? F("high") : F("low"));
client.print(F("<br><br>Click <a href='http://"));
client.print(WiFi.localIP());
client.print(F("/gpio/1'>here</a> to switch LED GPIO on, or <a href='http://"));
client.print(F("/gpio/0'>here</a> to switch LED GPIO off.</html>"));
// The client will actually be flushed then disconnected
// when the function returns and 'client' object is destroyed (out-of-scope)
// flush = ensure written data are received by the other side
Serial.println(F("Disconnecting from client"));
Once I compile and upload the sketch, the sketch is able to connect to my wifi network. The following is the output in the serial monitor.
20:45:12.633 -> Connecting to <text replaced xxxxxxx>
20:45:13.247 -> ........
20:45:17.551 -> WiFi connected
20:45:17.551 -> Server started
20:45:17.551 -> 192.168.0.39
I am able to verify the client connection in my wifi routers network management UI.
The espboard is connected and assigned the IP as in the output (192.168.0.39).
When I launch browser and try to get http://192.168.0.39/gpio/0, the request times out.
from my windows 10 pc, tried ping on 192.168.0.39, the Request timed out.
From the sketch I see the following lines in the loop() function:
if (!client) {
return;
The execution never reached the line Serial.println(F("new client"));.
I had tried inserting the line server = WiFiServer(80); after the wifi connection is established.
Please share your thoughts on why the server.available() is not successful?
