I bought a SainSmart Arduino Mega 2560. I uploaded a small sketch to it, and it uploaded fine. When I upload a larger sketch though, I get this error:
verification error, first mismatch at byte 0x3895
         0xdf != 0x44
So obviously there's nothing wrong with my bootloader because I can upload smaller files. Why is this happening?
user3042719
  • 151
If your sketch contains !!! in it, that can cause some versions of the bootloader to drop into interactive mode, eg.
Serial.println ("Rocket firing!!!");
Also there can be problems with 0xFF bytes in your code causing the bootloader to incorrectly assume that that page of memory was erased, when it was not.
I have a bootloader-uploader sketch at: Atmega bootloader programmer
You need a second board to use it (eg. a Uno) - the bootloader for the Mega2560 is a reasonably up-to-date one. I haven't actually tested it with the Sainsmart version of the Mega, but I presume that internally that part is the same.
Nick Gammon
  • 38,901
I believe I have finally understood this error today, and would like someone to verify or refute.
In "avrdude.conf" there is defined for each processor and for each memory type a minimum duration and a maximum duration that the programmer will repeat trying to write each byte. These have values of "min_write_delay = 4500" and "max_write_delay = 4500" (no idea what the units are).
After increasing the max_write_delay to "max_write_delay = 16000" (arbitrary increase but keeping it less than a 16 bit signed integer to avoid buffer overflow risks), for all memory types (but I would presume that only "flash" memory needs the parameter to be altered) my Arduino takes an extra 30 seconds to program, but no more verification errors.
