Can anyone please help me with this error?
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 2964 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 89 bytes (4%) of dynamic memory, leaving 1959 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcd
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcd
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
With enabled a in comment:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega168"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Documents\Arduino\libraries -fqbn=arduino:avr:diecimila:cpu=atmega168 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Mark\AppData\Local\Temp\arduino_build_293669 -warnings=none -build-cache C:\Users\Mark\AppData\Local\Temp\arduino_cache_250344 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Downloads Chrome\sketch_apr20a\sketch_apr20a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Documents\Arduino\libraries -fqbn=arduino:avr:diecimila:cpu=atmega168 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Mark\AppData\Local\Temp\arduino_build_293669 -warnings=none -build-cache C:\Users\Mark\AppData\Local\Temp\arduino_cache_250344 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Downloads Chrome\sketch_apr20a\sketch_apr20a.ino
Using board 'diecimila' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega168 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Servo.h: [Servo@1.1.6 Servo@1.1.3]
ResolveLibrary(Servo.h)
-> candidates: [Servo@1.1.6 Servo@1.1.3]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega168 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Documents\Arduino\libraries\Servo\src" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\avr\Servo.cpp
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\megaavr\Servo.cpp
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\sam\Servo.cpp
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\samd\Servo.cpp
Using cached library dependencies for file: D:\Documents\Arduino\libraries\Servo\src\stm32f4\Servo.cpp
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega168 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Documents\Arduino\libraries\Servo\src" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp" -o "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega168 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Documents\Arduino\libraries\Servo\src" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp" -o "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp.o"
Compiling libraries...
Compiling library "Servo"
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\avr\Servo.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\megaavr\Servo.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\nrf52\Servo.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\sam\Servo.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\samd\Servo.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\stm32f4\Servo.cpp.o
Compiling core...
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\hooks.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\WInterrupts.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring_analog.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring_shift.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring_digital.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\CDC.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\WMath.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\Print.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\WString.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\abi.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\Stream.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\Tone.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\new.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\USBCore.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\main.cpp.o
Using previously compiled file: C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\core\core.a
Archiving built core (caching) in: C:\Users\Mark\AppData\Local\Temp\arduino_cache_250344\core\core_arduino_avr_diecimila_cpu_atmega168_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega168 -o "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.elf" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\sketch\sketch_apr20a.ino.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\avr\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\megaavr\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\nrf52\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\sam\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\samd\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669\libraries\Servo\stm32f4\Servo.cpp.o" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/core\core.a" "-LC:\Users\Mark\AppData\Local\Temp\arduino_build_293669" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.elf" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.elf" "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.hex"
Multiple libraries were found for "Servo.h"
Used: D:\Documents\Arduino\libraries\Servo
Not used: C:\Program Files (x86)\Arduino\libraries\Servo
Using library Servo at version 1.1.3 in folder: D:\Documents\Arduino\libraries\Servo
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.elf"
Sketch uses 2964 bytes (20%) of program storage space. Maximum is 14336 bytes.
Global variables use 89 bytes (8%) of dynamic memory, leaving 935 bytes for local variables. Maximum is 1024 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega168 -carduino -PCOM4 -b19200 -D -Uflash:w:C:\Users\Mark\AppData\Local\Temp\arduino_build_293669/sketch_apr20a.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM4
     Using Programmer              : arduino
     Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x62
avrdude done. Thank you.
Python Schlange
  • 426
