For some reason my motor moves a certain amount every time I open the serial port without giving it any other instructions. It will move further by the same amount if I close and reopen the serial port. Please could someone tell me how to avoid this? I haven't had this problem before.
I am using two stepper motors with a A4988 driver each.
Here is my code so far
#include <AccelStepper.h>
#include <MultiStepper.h>
// Define pin connections const int dirPin1 = 2; const int stepPin1 = 3; const int dirPin2 = 4; const int stepPin2 = 5;
String incomingByte; // for incoming serial data
// Define motor interface type #define motorInterfaceType 1
// Creates an instance AccelStepper stepper1(motorInterfaceType, stepPin1, dirPin1); AccelStepper stepper2(motorInterfaceType, stepPin2, dirPin2);
MultiStepper steppers;
void setup() { Serial.begin(9600); String excess1 = Serial.readString(); // Configure each stepper stepper1.setCurrentPosition(0); stepper2.setCurrentPosition(0); stepper1.setMaxSpeed(100); stepper2.setMaxSpeed(100); stepper1.setAcceleration(10); stepper2.setAcceleration(10); // Then give them to MultiStepper to manage steppers.addStepper(stepper1); steppers.addStepper(stepper2); }
void loop() { // send data only when you receive data: if (Serial.available() > 0) { // read the incoming byte: incomingByte = Serial.readString();
// say what you got:
Serial.print(&quot;I received: &quot;);
//Serial.println(incomingByte, DEC);
Serial.println(incomingByte);
int x = incomingByte.toInt();
long positions[2];
positions[0] = x;
positions[1] = 0;
steppers.moveTo(positions);
steppers.runSpeedToPosition();
SPatel
When you open or reopen the Serial port, the Arduino resets (depending on how you open it; some programs don't send the signal on DTR or RTS, which result in the reset).
My guess is, that the stepper driver reacts to the Arduino configuring its pins for the stepper. Difficult to say, what exactly happens there. To mitigate that, you can add an external pulldown resistor (assuming you have an active high stepper driver. For active low use a pullup resistor). That should keep the step line of the driver low even when its not actively driven by the Arduino.
chrisl
  • 16,622
