For debugging purposes I want my serial connection to resume after sleep. After running LowPower.sleep() from the <ArduinoLowPower.h> library, I don't get any new serial messages in the serial monitor.
Several factors seem to be at play (which I've listed at the bottom) and I've developed a partial solution but it's not great because it requires some long artificial delays of about 1 second after each sleep to resume the serial. So to recap, my question is how I can get serial to work after sleeping the microcontroller without having to insert long delays.
For background, I am using an Adafruit Feather M0, which I think actually uses SerialUSB and automatically converts serial commands to that according to the guide, but I am not sure what any of that means.
Here's some stuff I looked into:
  1. COM Port: One factor is that the Arduino disconnects from the my Windows 10 computer at sleep and reconnects when it wakes up sometimes on a different COM port. Using the program Tera Term instead of the Arduino IDE Serial Monitor seems to keep it on the same COM port.
  2. Serial Flush and End: As notes in my code example, both of these commands seem necessary before sleeping or else I won't receive new messages after sleep.
  3. Delay: Seems that the arduino can send messages right after waking up that Tera Term wont see. I have to put a delay of 1 full second after waking up or else I won't see the messages.
Here's some code I have tried.
#include <ArduinoLowPower.h>
void setup() { Serial.begin(115200); while(!Serial){delay(10);} Serial.println("start"); }
Serial.println(""); Serial.println("sleep"); Serial.flush(); //if this line is commented out, only one cycle of "sleep" will show Serial.end(); //if this line is commented out, only one cycle of "sleep" will show //delay(2000); //doesn't seem to fix anything so commented out LowPower.sleep(2000); delay(1000); //at 750 misses some "awake" messages //Serial.begin(115200); //this line doesn't appear to fix anything so commented out Serial.println("awake");
Output:
start
sleep awake
sleep awake
sleep awake
rfii
  • 170
