my use case is that I am building a distance sensor using Arduino Uno. The idea is when the distance is between a threshold, an SMS is sent from the device.
I am using DS3231, SIM800L, and HCSR04 for my needs.
I want to save power consumption too so I am trying to put my Arduino into a deep sleep and then wake up using RTC interrupt.
The code below works fine when the distance is NOT in the threshold. Meaning Arduino is waking up by the interrupt and then doing what it needs to do. However, if the distance is in between the threshold the SMS is sent and received but after that Arduino never wakes up again. I checked out the SQW pin DS3231, using a multimeter and the signal indeed is going LOW, but Arduino does not wake up again.
Libraries that I am using, ds3231, Sim800l, NewPing
Here is the code that I am using,
#include <Arduino.h>
#include <avr/sleep.h>
#include <wire.h>
#include <ds3231.h>
#include <NewPing.h>
#include <Sim800L.h>
#define WAKEUP_PIN 2 // when low, makes 328P wake up, must be an interrupt pin (2 or 3 on ATMEGA328P) #define LED_PIN 13 // output pin for the LED (to show it is awake)
#define TRIGGER_PIN 7 #define ECHO_PIN 6 #define MAX_DISTANCE 200 //max distance we want to measure in cm NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
// DS3231 alarm time uint8_t wake_HOUR; uint8_t wake_MINUTE; uint8_t wake_SECOND;
static boolean goToSleep = false; //to track the when to go to sleep and when to get data and do stuff
#define SIM_MODULE_RX 10 #define SIM_MODULE_TX 11 Sim800L gsmModule(SIM_MODULE_RX, SIM_MODULE_TX);
///* A struct is a structure of logical variables used as a complete unit // struct ts { // uint8_t sec; /* seconds / // uint8_t min; / minutes / // uint8_t hour; / hours / // uint8_t mday; / day of the month / // uint8_t mon; / month / // int16_t year; / year / // uint8_t wday; / day of the week / // uint8_t yday; / day in the year / // uint8_t isdst; / daylight saving time / // uint8_t year_s; / year in short notation/ //#ifdef CONFIG_UNIXTIME // uint32_t unixtime; / seconds since 01.01.1970 00:00:00 UTC*/ //#endif //}; struct ts t;
// When WAKEUP_PIN is brought LOW this interrupt is triggered FIRST (even in PWR_DOWN sleep) void sleepISR() { // Prevent sleep mode, so we don't enter it again, except deliberately, by code sleep_disable();
// Detach the interrupt that brought us out of sleep
detachInterrupt(digitalPinToInterrupt(WAKEUP_PIN));
// Now we continue running the main Loop() just after we went to sleep
// Double blink just to show we are running. Note that we do NOT // use the delay for the final delay here, this is done by checking // millis instead (non-blocking) void doBlink() { static unsigned long lastMillis = 0;
if (millis() &gt; lastMillis + 1000)
    digitalWrite(LED_PIN, HIGH);
    delay(10);
    digitalWrite(LED_PIN, LOW);
    delay(200);
    delay(10);
    lastMillis = millis();
// Set the next alarm void setNextAlarm(void) { // flags define what calendar component to be checked against the current time in order // to trigger the alarm - see datasheet // A1M1 (seconds) (0 to enable, 1 to disable) // A1M2 (minutes) (0 to enable, 1 to disable) // A1M3 (hour) (0 to enable, 1 to disable) // A1M4 (day) (0 to enable, 1 to disable) // DY/DT (dayofweek == 1/dayofmonth == 0) uint8_t flags[5] = {0, 0, 0, 1, 1};
// get current time so we can calc the next alarm
DS3231_get(&amp;t);
wake_SECOND = t.sec;
wake_MINUTE = t.min;
wake_HOUR = t.hour;
// Add a some seconds to current time. If overflow increment minutes etc.
wake_SECOND = wake_SECOND + 10;
if (wake_SECOND &gt; 59)
    wake_MINUTE++;
    wake_SECOND = wake_SECOND - 60;
    if (wake_MINUTE &gt; 59)
        wake_HOUR++;
        wake_MINUTE -= 60;
// Set the alarm time (but not yet activated)
DS3231_set_a1(wake_SECOND, wake_MINUTE, wake_HOUR, 0, flags);
// Turn the alarm on
DS3231_set_creg(DS3231_CONTROL_INTCN | DS3231_CONTROL_A1IE);
void getDistance(){
// Send ping, get distance in cm
float distance = sonar.ping_cm();
// Send results to Serial Monitor
Serial.print(&quot;Distance = &quot;);
Serial.print(distance);
Serial.println(&quot; cm&quot;);
delay(500);
if (distance &lt; 10.00)
    //Setup Sim800 for sms sending
    gsmModule.begin(9600);
    bool err = gsmModule.sendSms(&quot;+91790xxxxxxx&quot;, &quot;CLose&quot;);
    Serial.println(err);
    gsmModule.end();
    delay(3000);
//sleep arduino after the above operation
goToSleep = true;
// Standard setup( ) function void setup() { Serial.begin(9600);
// Keep pins high until we ground them
pinMode(WAKEUP_PIN, INPUT_PULLUP);
// Flashing LED just to show the µController is running
pinMode(LED_PIN, OUTPUT);
// Clear the current alarm (puts DS3231 INT high)
Wire.begin();
DS3231_init(DS3231_CONTROL_INTCN);
DS3231_clear_a1f();
Serial.println(&quot;Setup completed.&quot;);
// The loop blinks an LED when not in sleep mode void loop() {
// Just blink LED twice to show we're running
doBlink();
// Is the &quot;go to sleep&quot; pin now LOW?
if (goToSleep == true)
    // Set the DS3231 alarm to wake up in X seconds
    setNextAlarm();
    // Disable the ADC (Analog to digital converter, pins A0 [14] to A5 [19])
    static byte prevADCSRA = ADCSRA;
    ADCSRA = 0;
    /* Set the type of sleep mode we want. Can be one of (in order of power saving):
     SLEEP_MODE_IDLE (Timer 0 will wake up every millisecond to keep millis running)
     SLEEP_MODE_ADC
     SLEEP_MODE_PWR_SAVE (TIMER 2 keeps running)
     SLEEP_MODE_EXT_STANDBY
     SLEEP_MODE_STANDBY (Oscillator keeps running, makes for faster wake-up)
     SLEEP_MODE_PWR_DOWN (Deep sleep)
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_enable();
    // Turn of Brown Out Detection (low voltage)
    // Thanks to Nick Gammon for how to do this (temporarily) in software rather than
    // permanently using an avrdude command line.
    // Note: Microchip state: BODS and BODSE only available for picoPower devices ATmega48PA/88PA/168PA/328P
    // BODS must be set to one and BODSE must be set to zero within four clock cycles. This sets
    // the MCU Control Register (MCUCR)
    MCUCR = bit(BODS) | bit(BODSE);
    // The BODS bit is automatically cleared after three clock cycles so we better get on with it
    MCUCR = bit(BODS);
    // Ensure we can wake up again by first disabling interupts (temporarily) so
    // the wakeISR does not run before we are asleep and then prevent interrupts,
    // and then defining the ISR (Interrupt Service Routine) to run when poked awake
    noInterrupts();
    attachInterrupt(digitalPinToInterrupt(WAKEUP_PIN), sleepISR, LOW);
    // Send a message just to show we are about to sleep
    Serial.println(&quot;Deep Sleep&quot;);
    Serial.flush();
    // Allow interrupts now
    interrupts();
    // And enter sleep mode as set above
    sleep_cpu();
    // µController is now asleep until woken up by an interrupt
    // Wakes up at this point when WAKEUP_PIN is brought LOW - interrupt routine is run first
    Serial.println(&quot;Awake&quot;);
    // Clear existing alarm so int pin goes high again
    DS3231_clear_a1f();
    // Re-enable ADC if it was previously running
    ADCSRA = prevADCSRA;
    goToSleep = false; //reset so that arduino does what it needs to do
else
    //check if distance is less
    Serial.println(&quot;Checking&quot;);
    getDistance();
TechMky
