Using python code for a serial port connection to an arduino, it sends a value to the arduino, which then starts printing values to serial. The python code will print the value on the first or second run (if run soon enough after), but after that it won't read what's from Serial.println again. To get it to read again (whether I wait some time or not, like for the while loop to finish), the arduino has to be unplugged and plugged in again, why is that different than the serial port connection being closed by python? Here is the arduino code used,
int measured;
int counter = 0;
int maxnum = 10;
void setup()
Serial.begin(9600);
void loop()
if(Serial.available() > 0)
while(counter < maxnum)
Serial.println("V");
counter++;
delay(100);
I know the value sent from python can be read because I added in code that reads from serial after checking if it's available and changed an output pin value, which works, even if the serial println is not read.
Edit: Since the answer is there shouldn't be a significant difference and the arduino script should be reset if the serial port was closed, the issue should be with the python code.
