I have to use a BNO055 to get temperature/accelerometer/Euler/Gyroscope data into one Arduino board for a school project. I am very new to coding so I am not familiar with the commands. I have gotten my BNO055 to give me all the data individually but I am having problems getting them all compiled into one code file to upload. I have googled it but I keep getting links to upload them individually. Posted below is my latest attempt.
#include <Wire.h> #include <Adafruit_Sensor.h> #include <Adafruit_BNO055.h> #include <utility/imumaths.h>Adafruit_BNO055 bno = Adafruit_BNO055(55);
void setup(void) { Serial.begin(9600); Serial.println("Orientation Sensor Test"); Serial.println("");
/* Initialise the sensor / if (!bno.begin()) { / There was a problem detecting the BNO055 ... check your connections */ Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!"); while (1); }
delay(1000);
bno.setExtCrystalUse(true); }
void loop(void) { /* Get a new sensor event */ sensors_event_t event; bno.getEvent(&event);
/* Display the current temperature */ int8_t temp = bno.getTemp();
Serial.print("Current Temperature: "); Serial.print(temp); Serial.println(" Celsius"); Serial.print(""); }
void loop(void) { /* Get a new Sensor event */ sensors_event_t event; bno.getEvent(&event);
imu::Vector<3> gyroscope = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
/* Display the floating point data */ Serial.print("X: "); Serial.print(gyroscope.x()); Serial.print(" Y: "); Serial.print(gyroscope.y()); Serial.print(" Z: "); Serial.print(gyroscope.z()); Serial.println(""); delay(100); }
imu::Vector<3> accelerometer = bno.getVector(Adafruit_BNO055::VECTOR_ACCELEROMETER);
/* Display the floating point data */ Serial.print("X: "); Serial.print(accelerometer.x()); Serial.print(" Y: "); Serial.print(accelerometer.y()); Serial.print(" Z: "); Serial.print(accelerometer.z()); Serial.println(""); delay(100); }
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
/* Display the floating point data */ Serial.print("X: "); Serial.print(euler.x()); Serial.print(" Y: "); Serial.print(euler.y()); Serial.print(" Z: "); Serial.print(euler.z()); Serial.println(""); delay(100); }
