I working on a project where I want to collect sensor data (from a sensor) and I want to analyze the first 20 data sample (e.g., find the range, trendline e.t.c.). I know how to compile a timer interrupt in Arduino IDE (using an ISR timer), but how would I be able to do this something similar (ISR timer) in MATLAB. The reason being, I want to collect my sensor data at exactly 20 Hz and using a delay function can prove to be inaccurate. Also, when I run a sample program that collects data in MATLAB, my sample frequencies change from 15Hz to even 24Hz (as shown below) . Does anyone have any suggestion on how I can do this? If the question is not clear enough I can elaborate more in the comments.
This is my MATLAB code:
clear all;
a = arduino('com4', 'uno');
i = 0;
v1 = zeros(1e4,1);
v2 = zeros(1e4,1);
x = zeros(1e4,1);
t = timer('TimerFcn', 'stat=false; disp(''Timer!'')',...
                 'StartDelay',5,'Period', 1);
start(t)
stat=true; tic while(stat==true) %while i<60 i = i + 1; v1(i) = readVoltage(a, 'A0'); v2(i) = readVoltage(a, 'A1'); x(i) = i; disp(x(i)); pause(.00001);
% end end toc
% %Plot voltage versus time v1 = v1(1:i); v2 = v2(1:i); x = x(1:i);
p = v1; n = v2; %Plot voltage versus time figure(1); plot(x,p,'-',x,n,'-') xlabel('Elapsed time (sec)') ylabel('v') title('Ten Seconds of voltage Data') %set(gca,'xlim',[t(1) t(i)]) legend('v1', 'v2');
% delete(t) % Always delete timer objects after using them.
Output is
>> Timer
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
Timer! 76
Elapsed time is 5.032553 seconds. >>
I apologize for the long output. But as you can see, I specified a pause time of .00001, which should give me well over a 20Hz sampling frequency. But I only get 76 samples/5 seconds = 15.2Hz. Also, sometime when I run this the program may collect 79sample/5secons, or even 121sample/5seconds. It just is not consistent. I was hoping to solve this with a timer interrupt that will be hard coded in MATLAB to collect data at exactly 20Hz. Please let me know what y'all think. Thank you.
I've configured the timer differently making use of its UserData property. The timer will update the data every fixed period for a specified number of samples.
close all;
clear all;
% Some useful constants. NUM_SAMPLES = 20; PERIOD = 0.05;
global a; a = arduino('com4', 'uno');
% Initialise data. It will be updated by the timer. data.i = 0; data.v1 = zeros(NUM_SAMPLES, 1); data.v2 = zeros(NUM_SAMPLES, 1); data.x = (1:NUM_SAMPLES) * PERIOD;
% Initialise timer for a fixed period for a specific number of samples. t = timer; t.ExecutionMode = 'fixedRate'; t.Period = PERIOD; t.TasksToExecute = NUM_SAMPLES; t.TimerFcn = @TimerCallback; t.UserData = data;
% Run the timer and wait for it to complete. start(t); wait(t); stop(t); data = t.UserData; % Retrieve the updated data. delete(t);
% Plot voltage versus time. figure(1); plot(data.x, data.v1, '-', data.x, data.v2, '-'); xlabel('Elapsed time (s)'); ylabel('Voltage (V)'); title('Voltage Data'); st = sprintf("%0.3f seconds", NUM_SAMPLES * PERIOD); subtitle(st); legend('v1', 'v2');
function TimerCallback(obj, event) global a; obj.UserData.i = obj.UserData.i + 1; obj.UserData.v1(obj.UserData.i) = readVoltage(a, 'A0'); obj.UserData.v2(obj.UserData.i) = readVoltage(a, 'A1'); end
tim
  • 699
Each communication with Arduino takes 20ms, you have two in the loop so in the ideal conditions you could get 25 readings/second. See here the source
This also depends on the size of the data you request.
I think this is what you are looking for but I cant give you any advice since I don't have Matlab and Octave is not having this feature.
Dorian
  • 369
