I have been trying to get the Arduino bootloader to compile into my firmware binary in Atmel Studio. I got the bootloader project to link and compile. I use ArduinoCore and the bootloader as a dependencies to my main code. The dependency tree looks like:
  1. ArduinoCore
  2. bootloader
  3. Main firmware
The Bootloader
It took me a bit to get the bootloader to accept the rest of ArduinoCore as a dependency but it compiles into a static library. I use the bootloader linker to specify the memory location of the bootloader binary. It should start at 0x0 and provide a jump to the main firmware, located at 0x2000.
Bootloader linker flags:
-Tbootloader_samd21x18.ld -Wl
And here are the contents of the linker script:
  FLASH (rx) : ORIGIN = 0x00000000, LENGTH = 0x2000 /* First 8KB used by bootloader */
  RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00008000-0x0004 /* 4 bytes used by bootloader to keep data between resets */
This is based off of the .cProj file that comes with the linker. It is compiled as a static library so I can include it into my final binary.
Main Firmware
My code has both the ArduinoCore and the bootloader static libraries as dependencies:
libm
libArduinoCore
libbootloader
And I am using these linker flags:
-Tflash_with_bootloader.ld -Wl,--cref -Os -Wl,--check-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align
The contents of this linker script are moved out by 8KB in order to accommodate the bootloader at the start of the binary:
    FLASH (rx) : ORIGIN = 0x00000000+0x2000, LENGTH = 0x00040000-0x2000  /* First 8KB used by bootloader */
And yet, my entry point does not appear to ever hit the bootloader. It jumps straight to "main.cpp" from ArduinoCore. The firmware runs as expected, but the bootloader does not appear to have been included.
Is this some kind of dependency issue? Am I misusing the linkers?
Any help with getting this to compile under a single binary would be very much appreciated. Thank you very much!
Andrew
  • 107
This isn't exactly 100% the answer I was looking for, because I still want to know how I can use a static library build, as I mention in my post, and compile everything as a single binary. This method is essentially gluing two binaries together.
I found this great and informative post over here: https://www.avrfreaks.net/forum/can-you-combine-appbootloader-using-as7
It uses srec_cat to concatenate two binaries after building them: https://www.keil.com/support/docs/2666.htm
I use the offset specified from the '.ld' file using
srec_cat <firmware1.bin> -Binary <firmware2.bin> -Binary -offset 0x2000 -o <firmwareOut.bin>
As the post suggests, I set this up as a post-build event and set my build dependencies accordingly so that a full clean and make will produce a consolidated binary including the bootloader.
If anyone tries this, make sure you only use the non-bootloader binary generated by your main project build. The bootloader places new firmware at location 0x2000 and your firmware will break if it finds a bootloader at the location where the firmware is supposed to be. When uploading firmware to the bootloader, it does not overwrite the bootloader.
Andrew
  • 107
