I want my ESP8266-based device to create an accesspoint that allows the user to input their home ssid and password. There is a device object that holds most of the data defined elsewhere.
I'm trying to use the ESP8266WebServer library. It requires me to define parameterless callback functions. Where should I declare and define these callback functions so that they can access the server object? In all the example code, the server object is global. I'd want to avoid that, and I'd also like to avoid having a server object as a permanent Device class member.
How should I go about this? It is not allowed to define the callback functions inside Device::getWifiCredentials, and if I declare them outside then server isn't in scope.
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
// Function to create AccessPoint to get ssid and password int Device::getWifiCredentials() {
ESP8266WebServer server(80);
server.begin();
// define callbacks
server.on(&quot;/&quot;, handleRoot); // initial page
server.on(&quot;/ssid&quot;, handleCredentials); // catch response from initial page
// wait for credentials to be delivered
server.handleClient();
while( WiFi.status() != WL_CONNECTED){
    Serial.print(&quot;.&quot;);
    delay(500);
return ACTION_SUCCESSFUL;
// Where can these functions be defined to allow them to access the server object?
void handleRoot() { };
void handleCredentials() {
String ssid;
String pw;
if( server.hasArg() ){
    ssid = server.arg(&quot;ssid&quot;);
    pw = server.arg(&quot;pw&quot;);
LearnDude
put your server declaraition outside the constructor and call a class callback :
// Function to create AccessPoint to get ssid and password int Device::getWifiCredentials() { server.begin();
// define callbacks
server.on(&quot;/&quot;, std::bind(&amp;Device::handleRoot, this); // initial page
server.on(&quot;/ssid&quot;, std::bind(&amp;Device::handleCredentials, this); // catch response from initial page
    delay(500);
eltharin
