I'm creating an Arduino library and have 3 files - a "test.ino" program, and two library/class files: "testLibrary.h" and a "testLibrary.cpp".
The library makes use of some hardware-specific resources such as registers and ISRs that depend upon which I/O pin is used, and this should be done at compile time.
I would like to #define a pin number in the main program which, at compile time, is used in the library to determine which code sections are activated. Since this will be a standard Arduino library for use by others, it should compile and run without users having to change their compiler or #include path to make it work.
But it seems that the scope of #define in the main program/sketch does not extend to the library.
test.ino
#define PIN_NUMBER 3
#include "testLibrary.h"
void setup() {}
void loop() {}
testLibrary.h
#ifndef _TESTLIBRARY_h
#define _TESTLIBRARY_h
#ifndef PIN_NUMBER
#error PIN is not defined
#endif
class test {
public:
test();
~test();
#endif
testLibrary.cpp
test::test(){}*
test::~test(){}
Compiling the above branches to "#error" using the Arduino IDE 1.8.13 and also using Visual Studio with Visual Micro.
Is there a way for me to have an Arduino library use a "#define" from the main sketch?
