I have a Python program that acts as a Firmata client. This program connects to the Arduino at a user-specified COM-port (with Firmata onboard, the sketch can be seen below), sends the user-requested string message to the Arduino, and awaits Arduino's reply. If the reply is present, the program prints it out as a list of ASCII symbol codes.
I expect the program and the sketch to work this way (block scheme is below), but the strings coming from the Arduino are damaged. They don't contain all symbols which were sent, but they contain only the first symbols in some random order, with a \0 symbol present after each character in the string. For example,
| String sent to the Arduino | Received as ASCII symbol codes | Received as a string |
A |
(65, 0) |
A\0 |
AB |
(65, 0) where is the B? |
A\0 |
ABC |
(65, 0, 67, 0) the B lacks presence |
A\0C\0 |
ABCD |
(65, 0, 67, 0) the received data length remains the same, but B and D aren't present |
A\0C\0 |
ABCD(10) |
(65, 0, 67, 0, 40, 1, 48, 1) WHAT IS THIS? |
A\0C\0(\10\1 |
DHTt(4) |
(68, 0, 84, 0, 40, 0, 41, 1) |
D\0T\0(\0)\1 |
Program's screenshot:
Awaited work algorithm block scheme:
Python program code:
import pyfirmata, time
class CustomArduino(pyfirmata.Arduino):
def init(self, port: str):
pyfirmata.Arduino.init(self, port)
self.iterator = pyfirmata.util.Iterator(self)
self.iterator.start()
self.add_cmd_handler(0x71, self.receiveString)
def receiveString(self, *args, **kwargs):
print(f'Received: {args}')
def sendString(self, data):
self.send_sysex(0x71, bytearray(data, 'utf-8'))
def send_sysex(self, sysex_cmd, data=[]):
Sends a SysEx msg.
:arg sysex_cmd: A sysex command byte
: arg data: a bytearray of 7-bit bytes of arbitrary data
msg = bytearray([pyfirmata.pyfirmata.START_SYSEX, sysex_cmd])
msg.extend(data)
msg.append(pyfirmata.pyfirmata.END_SYSEX)
self.sp.write(msg)
print('STRING TESTER\nPlease input your COM port: ', end = '')
myCom = str(input())
device = CustomArduino(myCom)
while True:
device.sendString(input('Send: '))
time.sleep(1)
Arduino sketch:
#include <Firmata.h>
void stringCallback(char myString)
//The function accepts one charset.
Firmata.sendString(myString); //send the same* charset back
void sysexCallback(byte command, byte argc, byte *argv)
Firmata.sendSysex(command, argc, argv);
void setup()
Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
Firmata.attach(STRING_DATA, stringCallback); //when there is a STRING incoming to the Arduino, call 'stringCallback'
Firmata.attach(START_SYSEX, sysexCallback);
Firmata.begin(57600);
pinMode(13, OUTPUT);
void loop()
while (Firmata.available()) {
Firmata.processInput();
How I can deal with this?
