I have been stuck for a long time on a piece of Arduino code that performs an FFT on a Photoplethysmogram signal and decides signal quality after that.
#include <math.h>
#include "arduinoFFT.h"
#include <EEPROM.h>
//N=10 pt moving average //For bidmc data of first 10 patients, MA = 0.4613849 double baseline=0.4613849; float lm=1.0; //amplitude threshold float ref_voltage=1.0; //saturation reference voltage float cutoff=4.0; float fs=0.02; float zero_amp=0.015;
float pi=3.14159265; //Universal Constants float e=2.71828; const int flen=61;
#define SAMPLES 128 //Must be a power of 2 #define SAMPLING_FREQUENCY 50 //Hz, must be less than 10000 due to ADC
arduinoFFT FFT = arduinoFFT(); unsigned int sampling_period_us; unsigned long microseconds;
double vReal[SAMPLES]; double vImag[SAMPLES];
void setup() { Serial.begin(9600); sampling_period_us = round(1000000*(1.0/SAMPLING_FREQUENCY)); }
void loop() { //float arr[]={0.43597,0.43206,0.42815,0.42424,0.42131,0.41838,0.4174,0.41642,0.41544,0.41447,0.41251,0.41153,0.40958,0.40762,0.40665,0.40665,0.40665,0.40762,0.4086,0.4086,0.41056,0.41153,0.41153,0.41056,0.4086,0.40665,0.40469,0.40469,0.40567,0.4086,0.41251,0.42033,0.43206,0.45259,0.4741,0.4956,0.51808,0.5347,0.55034,0.56403,0.57576,0.58456,0.59238,0.59629,0.59922,0.60117,0.60215,0.60313,0.60313,0.60117,0.59824,0.59335,0.58553,0.57771,0.57185,0.56207,0.54741,0.53372,0.52102,0.50929,0.50244,0.49756,0.4956,0.49462,0.49365,0.49365,0.49365,0.49169,0.48876,0.4868,0.48387,0.48094,0.47801,0.47507,0.47116,0.46823,0.46334,0.45846,0.45357,0.44868,0.44379,0.43891,0.435,0.43109,0.4262,0.42326,0.42033,0.41838,0.41642,0.41447,0.41447,0.41349,0.41251,0.41251,0.41251,0.41251,0.41251,0.41349,0.41544,0.4174,0.41935,0.42033,0.42131,0.42131,0.42033,0.41935,0.41642,0.41447,0.41349,0.41349,0.41642,0.42131,0.42815,0.43695,0.45064,0.46823,0.4868,0.50538,0.52395,0.54154,0.55816,0.57185,0.58162,0.58749,0.59042,0.59042,0.5914,0.59042,0.58944,0.58651,0.5826,0.57771,0.57087,0.56305,0.5523,0.54057,0.52884,0.51711,0.50733,0.49756,0.48778,0.47996,0.4741,0.47019,0.46823,0.46725,0.46628,0.46432,0.46041,0.4565}; float arr[]={0.30303,0.29814,0.29326,0.28837,0.28446,0.28152,0.27859,0.27468,0.26979,0.26393,0.25806,0.25611,0.25904,0.27175,0.29521,0.32942,0.37341,0.42522,0.47116,0.51417,0.55914,0.6002,0.63539,0.66373,0.68622,0.70381,0.71652,0.72532,0.73118,0.73314,0.73314,0.73021,0.7263,0.72043,0.71359,0.70479,0.69501,0.68524,0.67351,0.6608,0.64614,0.6305,0.61388,0.59726,0.58065,0.56207,0.54252,0.52395,0.50538,0.48778,0.47312,0.46041,0.44868,0.43988,0.43304,0.42815,0.42522,0.42229,0.41935,0.4174,0.41544,0.41349,0.41056,0.40762,0.40469,0.40176,0.39785,0.39394,0.39003,0.38612,0.38221,0.37634,0.37146,0.36559,0.35973,0.35386,0.348,0.34213,0.33627,0.3304,0.32551,0.32258,0.31769,0.31281,0.30792,0.30303,0.29814,0.29423,0.28935,0.28446,0.27957,0.2737,0.26784,0.26393,0.261,0.26197,0.26882,0.28446,0.31183,0.34897,0.39589,0.44868,0.50147,0.55132,0.59629,0.6305,0.65591,0.67937,0.69795,0.71261,0.72434,0.73216,0.73607,0.73803,0.73803,0.73509,0.73021,0.72434,0.7175,0.70968,0.6999,0.69013,0.6784,0.66569,0.65103,0.63441,0.61681,0.59824,0.57771,0.55718,0.53959,0.52297,0.50635,0.48974,0.47507,0.46334,0.45259,0.44379,0.43695,0.43206,0.42815,0.42522,0.42229,0.42033,0.41838,0.41642,0.41447,0.41153,0.4086,0.40469,0.40078,0.39687,0.39198,0.3871,0.38221,0.3783,0.37439,0.3695,0.36364,0.35875,0.35288,0.348,0.34213,0.33724,0.33236,0.32747,0.32258,0.31769,0.31378,0.31085,0.30792,0.30401,0.3001,0.29619,0.29032,0.28446,0.27859,0.2737,0.2737,0.28055,0.29423,0.31672,0.35191,0.39785,0.45161,0.50733,0.56109,0.60899,0.65005,0.68328,0.7087,0.72727,0.74096,0.74878,0.75367,0.75562,0.7566,0.75464,0.75171,0.74585}; //float arr[]={0.30303,0.28446,0.26979,0.25904,0.37341,0.55914,0.68622,0.73118}; int len=sizeof(arr)/sizeof(arr[0]);
/for(int i=0;i<sizeof(arr)/sizeof(arr[0]);i++) //ppg data Array display { Serial.println(arr[i]);
delay(50); }
//SAMPLES=len; for(int i=0; i<SAMPLES; i++) { microseconds = micros(); //Overflows after around 70 minutes! vReal[i] = arr[SAMPLES]; vImag[i] = 0;
    while(micros() &lt; (microseconds + sampling_period_us)){
/FFT/ FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD); FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD); FFT.ComplexToMagnitude(vReal, vImag, SAMPLES); double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
/PRINT RESULTS/ //Serial.println(peak); //Print out what frequency is the most dominant.
for(int i=0; i<(SAMPLES/2); i++) { /View all these three lines in serial terminal to see which frequencies has which amplitudes/ Serial.print((i * 1.0 * SAMPLING_FREQUENCY) / SAMPLES, 2); Serial.print(" "); Serial.println(vReal[i], 1); //View only this line in serial plotter to visualize the bins delay(50); }
//delay(1000); //Repeat the process every second OR: //while(1); //Run code once Serial.println("Hello"); //int freq_N=61; for (int i = 0 ; i < EEPROM.length() ; i++) { EEPROM.write(i, 0); }
/double D[3][freq_N]; //1st row for frequencies, 2nd row for magnitude, 3rd row for phase for(int i=0;i<freq_N;i++) { D[0][i]=-(pi/2)+i0.1; double d=fourier_tran(arr,len,D[0][i]); D[1][i]=(d+0); D[2][i]=(d+1); Serial.println(i); delay(300); }/
int z_crsg=zero_cross(arr,len); //Serial.println(z_crsg); //delay(1000); float diff_arr[len-1]; //Differenced PPG signal for(int i=1;i<=len-1;i++) { diff_arr[i-1]=arr[i]-arr[i-1]; }
int rise=rise_count(arr,len); int fall=fall_count(arr,len); float fr=(float)fall/rise; //fall/rise count ratio uint16_t m=max_amplitude(arr,len); //maximum amplitude detection int sc[]={0,0,0}; //sensor connectivity vector if(fr>1.65 && fr<2.35) { sc[0]=1; } if(m<lm) { sc[1]=1; } if(m>zero_amp) { sc[2]=1;; } int sd=sig_saturation(arr,len); //Serial.println(sd); //Serial.print(sc[0]); //Serial.print(sc[1]); //Serial.print(sc[2]);
if(sum(sc,3)>=2) { Serial.println("Sensor well connected"); } else { Serial.println("Sensor not connected properly"); } delay(500); if(base_drift(arr,len)>=0.4612 && base_drift(arr,len)<=0.4614) { Serial.println("Motion detected"); } else { Serial.println("No motion artefacts problems"); } delay(500); if(sd==0) { Serial.println("Saturated signal"); } else { Serial.println("Non-saturated signal"); } delay(500);
int d_z_crsg=zero_cross(diff_arr,len-1);
//Sensor connectivity detection int fall_count(float arr[],int l) { int c=0; for(int i=0;i<l-1;i++) { if(arr[i]>arr[i+1]) { c=c+1; } } return c; } int rise_count(float arr[],int l) { int c=0; for(int i=0;i<l-1;i++) { if(arr[i]<arr[i+1]) { c=c+1; } } return c; } int max_amplitude(float arr[],int l) { float h=arr[0]; for(int i=1;i<l;i=i+1) { if(arr[i]>h) { h=arr[i]; } } if(h>lm) { return 0; } return 1;
//Noise segment detection int zero_cross(float arr[],int l) { int c=0; for(int i=0;i<l-1;i++) { if((arr[i]==0.0) && arr[i+1]!=0.0) { c=c+1; } } return c; } int local_maxima(float arr[], int l) { int frame_len=15; int a=0; int frames=l/frame_len; int maxima[frames]; for(int k=0;k<frames;k++) { uint16_t h=0; for(int i=a;i<a+frame_len;i++) { if(arr[i]>h) { h=arr[i]; } } maxima[k]=h; a=a+frame_len; } for(int i=0;i<frames-1;i++) { if(maxima[i]>lm && maxima[i+1]>lm) { return 1; } if(i<=frames-4) { if(maxima[i]<lm && maxima[i+1]<lm && maxima[i+2]<lm && maxima[i+3]<lm) { return 1; } } if(i<=frames-3) { if(maxima[i]<lm && maxima[i+2]<lm) { return 1; } } } return 0; }
//Saturation detection int sig_saturation(float arr[],int l) { int c=0; //uint16_t lev=200000; for(int i=0;i<l-1;i++) { if(arr[i]<10 && arr[i+1]<10) { c++; }
if(arr[i]&gt;lm &amp;&amp; arr[i+1]&gt;lm)
  c++;
} if(c>=20) { return 0; } return 1; }
//motion detection module double base_drift(float arr[],int l) { int N=10; //N pt moving average int frame=l-N+1; //number of frames float s=0; double sum=0; for(int i=0;i<frame;i++) { s=0; for(int j=i;j<N+i;i++) { s=s+arr[j]; } sum=sum+(s/N); } double avg=sum/frame; return avg; }
int sum(int n[],int l) { float s=0; for(int i=0;i<l;i++) { s=s+n[i]; } return s; }
float butterworth(float f, float fc,int n) { float h; h=1/sqrt(1+pow((fc/f),2*n)); return h; }
double fourier_tran(float arr[],int n,float omega) { double Xr=0.00; double Xi=0.00; double DTFT[2]; for(int j=0;j<n;j++) { Xr=Xr+arr[j]cos(omegaj); Xi=Xi+arr[j]sin(omega*j); } float X=sqrt(pow(Xr,2)+pow(Xi,2)); //Fourier transform magnitude float ph=-atan(Xi/Xr); //Fourier transform phase
DTFT[0]=X; DTFT[1]=ph; double p=DTFT; Serial.println(p); delay(100); Serial.println((p+1)); delay(100); return p; } float inv_fourier(float DTFT[][flen],int l,int flen,int n) //n is the length of the time array { float arr[n]; for(int i=0;i<n;i++) { float X=0.000; for(int j=0;j<l;j++) { X=X+DTFT[1][j]cos(DTFT[2][j]+DTFT[0][j]n); } arr[i]=1/(2pi) X; } float *p=arr; return p; }
When I upload the code, Right after performing the FFT, the code does not display anything more, implying it ceases to execute and shows an error message - Not enough memory; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing your footprint. data section exceeds available space in board
I cannot remove either section of the code, so what do I need to change with this?
Probably you use too much SRAM memory:
float arr[] seems to take 4 bytes (for float) * 128 = 512 bytes.
Then you have vReal and `vImage which takes 4 (double, float/doubles are the same in Arduino) * 128 * 2 (vReal/vImage) = 1024 bytes.
This already is 1536 bytes. The Arduino only has 2048 bytes so high likely you exceed it (including arguments passed and other globals).
arr seems to be a readonly array, so check into the use of F/PROGMEM to store them in Flash instead of SRAM (see StarCat's comment). This might get you well under the 2 KB Arduino Uno memory. Other possibilities are using a Mega which has 8 KB or use external SRAM memory but this decreases performance and takes more programming effort.
See also my anser at Optimizing code to use less Flash Memory and SRAM
Michel Keijzers
  • 13,014
  • 41
  • 58
Consider using one of the Teensy family. The latest Teensy 4.0 has an onboard FPU and lots of other goodies, and runs at 600MHz. Why drive a VW when you can jump into a Ferrari for very little money?
I've been using the Teensy 3.2/3.5 modules for years, and have found them to be very stable and easy to use.
starship15
  • 782
