I have a function for HTTP_POST responses but it is never called when I post to it. I get the webpage instead.
I call on it with
server.on("/",HTTP_POST,response);
But I only get the url in response.
pinMode(led_pin, OUTPUT);
Serial.begin(115200);
#if defined(AVR_ATmega32U4) || defined(SERIAL_USB) || defined(SERIAL_PORT_USBVIRTUAL)
delay(2000); // To be able to connect Serial monitor after reset and before first printout
#endif
// Just to know which program is running on my Arduino
Serial.println(F("START " FILE " from " DATE));
Serial.print(F("Ready to send IR signals at pin "));
Serial.println(IR_SEND_PIN);
digitalWrite(led_pin, 0);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
if (MDNS.begin("esp32")) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/test.svg", drawGraph);
server.on("/inline", []() {
server.send(200, "text/plain", "this works as well");
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void response(){
//int khz = 38; // 38kHz carrier frequency for the NEC protocol
if(server.hasArg("on") && (server.arg("on").length()>0)){ // TODO check that it's not longer than 31 characters
Serial.print("Server was turned on:\t");
Serial.println(server.arg("on"));
++CYCLE0;
server.sendHeader("Location", String("/"), true); //how to do a redirect, next two lines
server.send ( 302, "text/plain", "");
} else if (server.hasArg("off") && (server.arg("off").length()>0)){
Serial.print("Server was turned off:\t");
Serial.println(server.arg("off"));
++CYCLE1;
} else if (server.hasArg("up") && (server.arg("up").length()>0)){
Serial.print("Server temp was turned up:\t");
Serial.println(server.arg("up"));
++CYCLE2;
} else if (server.hasArg("down") && (server.arg("down").length()>0)){
Serial.print("Server temp was turned down:\t");
Serial.println(server.arg("down"));
++CYCLE3;
} else {
server.send(400, "text/html", "<html><body><h1>HTTP Error 400</h1><p>Bad request. Please enter a value.</p></body></html>");
How do you get an http post response back instead of a webpage?
POST response:
<html>
<head>
<meta http-equiv='refresh' content='5' />
<title>ESP32 Demo</title>
<style>
body {
background-color: #cccccc;
font-family: Arial, Helvetica, Sans-Serif;
Color: #000088;
</style>
</head>
<body>
<h1>Hello from ESP32!</h1>
<p>Uptime: 00:05:32</p> <img src="/test.svg" />
<h2>Turn air condistioner on</h2>
<p>AC has been cycled 0 times</p>
<form name='frm0' method='post'> <input type='text' name='on' value=8000>
<input type='submit' value='Submit'> </form>
<p>Turn air conditioner off 0 times</p>
<form name='frm1' method='post'> <input type='text' name='off' value=8000>
<p>Turn temperature up 0 times</p>
<form name='frm2' method='post'> <input type='text' name='up' value=8000>
<p>Turn temperature down 0 times</p>
<form name='frm3' method='post'> <input type='text' name='down' value=8000>
</body>
</html>
Complete code
