I've got an Arducam OV2640 which takes a picture as a JPEG that I'd like to send to another Arduino using a pair of nRF24L01 wireless transceivers to eventually display it on an SSD1351 OLED.
Unfortunately, because the JPEG data is so large, it's being handled in a way I'm unfamiliar with, and I've also never really tried sending any data between Arduinos, let alone a JPEG, but I'm hoping that won't stop me.
The code I've posted below for the camera seems to be reading from a FIFO buffer that I'm assuming is on the camera module itself. Based on how it's saving it to the SD card, I know when I send it to the Arduino I have to send it in chunks and tell it how many chunks, when to start, and when to stop, but I'm having trouble finding good resources on how exactly to do that.
Currently, the code saves it to an SD card. My plan was to send the data to the second Arduino, have it save it to the SD card, and then display the JPEG from the SD card onto the OLED, but if I could skip the SD read/write that'd be preferable.
Camera code:
#include <ArduCAM.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
#define SD_CS 10
const int SPI_CS = 7;
ArduCAM myCAM( OV2640, SPI_CS );
uint8_t vid, pid;
uint8_t temp;
Wire.begin();
Serial.begin(9600);
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(SPI_CS, OUTPUT);
digitalWrite(SPI_CS, HIGH);
// initialize SPI:
SPI.begin();
// Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1) {
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55) {
Serial.println(F("SPI interface Error!"));
delay(1000);
continue;
} else {
Serial.println(F("SPI interface OK."));
break;
//Initialize SD Card
while (!SD.begin(SD_CS)) {
Serial.println(F("SD Card Error!"));
delay(1000);
Serial.println(F("SD Card detected."));
while(1) {
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))) {
Serial.println(F("Can't find OV2640 module!"));
delay(1000);
continue;
} else {
Serial.println(F("OV2640 detected."));
break;
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_320x240);
delay(1000);
myCAMSaveToSDFile();
delay(5000);
void myCAMSaveToSDFile() {
char str[8];
byte buf[256];
static int i = 0;
static int k = 0;
uint8_t temp = 0, temp_last=0;
uint32_t length = 0;
bool is_header = false;
File outFile;
// Flush the FIFO
myCAM.flush_fifo();
// Clear the capture done flag
myCAM.clear_fifo_flag();
// Start capture
myCAM.start_capture();
Serial.println(F("start Capture"));
while(!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK));
Serial.println(F("Capture Done."));
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) { // 384K
Serial.println(F("Over size."));
return;
if (length == 0 ) { // 0 kb
Serial.println(F("Size is 0."));
return ;
// Construct a file name
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if (!outFile) {
Serial.println(F("File open faild"));
return;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while (length--) {
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ((temp == 0xD9) && (temp_last == 0xFF)) { // If find the end, break while
buf[i++] = temp; // save the last 0XD9
// Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
// Close the file
outFile.close();
Serial.println(F("Image save OK."));
is_header = false;
i = 0;
if (is_header == true) {
// Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
else {
// Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
} else if ((temp == 0xD8) & (temp_last == 0xFF)) {
is_header = true;
buf[i++] = temp_last;
buf[i++] = temp;
Transmitter Code:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
radio.stopListening();
const char text[] = "Hello World";
radio.write(&text, sizeof(text));
delay(1000);
Receiver Code:
#include <SPI.h>
#include <RF24.h>
Serial.begin(9600);
radio.begin();
radio.openReadingPipe(0, address);
radio.startListening();
if (radio.available()) {
char text[32] = "";
radio.read(&text, sizeof(text));
Serial.println(text);
So I know the JPEG is too big to be saved to a variable, so I can't just Radio.write it out and I have to hijack the loop being done in the SD card saving code.
I'm just so unfamiliar with this part of Arduino, I could really use some advice on how to make it work.
