Below is the entirety of my prototype code, the cycling of pin 13 is what I use to confirm the board is restarting. The board resets continually on this implementation of initialising the interrupt. There is no code implemented for the interrupt, simply initialising the interrupt and specifically enabling the Output Compare Interrupt by setting its bit high is enough to cause the crash. The evidence of the crash is the onboard LED cycling as instructed in the setup() routine.
I have tried setting OCR3A in one and two operations, I have tried initialising TIMSK3 and not, I have tried intialising TCNT3 to zero and non-zero values, and setting the prescaler with the bit shift and the discrete value, nothing seems to work..
What is going on?
void FlashLED() {
digitalWrite(13, !digitalRead(13));
delay(100);
delay(100);
delay(100);
delay(100);
pinMode(13, OUTPUT);
FlashLED();
// Initialise timer 3 and interrupt
noInterrupts();
TCCR3A = 0;
TCCR3B = 0;
TIMSK3 = 0;
TCNT3 = 0;
// Initialise OCR3A in two operations, as OCR3A = 62500; Serial.print(OCR3A); yields 36 (low byte only)
unsigned int count = 62500;
OCR3AH = count >> 8;
OCR3AL = count;
TCCR3B |= 1 << WGM32; // CTC Mode
//TCCR3B |= 4; // Prescaler 256
TCCR3B |= 1 << CS32; // Prescaler 256
TIMSK3 |= 1 << OCIE3A; // Output Compare Interrupt Enable
interrupts();
// put your main code here, to run repeatedly:
Update:
I had also been trying with an empty ISR handler and discounted its effect:
ISR(Timer3_COMPA_vect) {
However, as the astute viewer would notice, the signature is incorrect in its capitalisation. The correct handler is
ISR(TIMER3_COMPA_vect) {
This has resolved the issue.
