Can normal buzzer be used for generating high frequency audio and if this is possible then can normal microphone module be able to detect the same frequency range(15 kHz - 20 kHz).
Here is the specifications of this buzzer:-
Rated Voltage : 6V DC
Operating Voltage : 4 to 8V DC
Rated Current* : ≤30mA
Sound Output at 10cm* : ≥85dB
Resonant Frequency : 2300 ±300Hz
Tone : Continuous
Operating Temperature : -25°C to +80°C
Storage Temperature : -30°C to +85°C
Weight : 2g
*Value applying at rated voltage (DC)
Buzzermicrophone-module
astrick
  • 193
An arduino is very well capable of producing a 20KHz signal. You can use a PWM signal on one of the PWM pins, generate the signal by alternating a pin high and low with a few microseconds in between or you can use a buzzer with an input signal that can play a continuous tone at a specified frequency. I really can't see if the module you show can generate a tone based on the input.
Detecting a tone, however is somewhat difficult. You need an analog microphone amplifier, an ADC (analog-to-digital-converter) and some processing to detect a frequency in the signal data.
The usual microphone modules that are sold for arduino's are mostly just noise detectors and generate a signal when loud noise is present.
Hacky
  • 154
As others have noted, the frequency range of the buzzer is given in the data sheet. This is a mechanical property, like the tone of a bell; you can't change it electrically. So if you really need to generate high frequency audio, you need a different type of device. Something like a speaker whose output is controlled by its input signal. You don't mention what you are planning on using this for, which might make a difference in your options. There are inexpensive piezo tweeters that work in this range, but they typically have very ragged frequency responses. Actually, most transducers in this range do, but dynamic types tend to be better, though more expensive and less efficient.
If you want to generate controllable high frequencies with Arduino, you might want to look at my open-source DaqPort sketch. This is intended to be controlled by a computer over USB and includes data acquisition as well as generation, but the oscillator portion can run as a stand-alone. The sketch is included with my Daqarta software, which is free for Arduino use. Daqarta includes the Arduino_Oscillators mini-app, which is described here: https://www.daqarta.com/dw_rrss.htm The oscillators are also used by the DaquinOscope mini-app https://www.daqarta.com/dw_rrss.htm which does simultaneous acquisition, but it uses the computer for display so it's not stand-alone.
Microphones should not be a problem; many inexpensive electrets can handle this range. But we really need to know more about your plans.
Boggyman
  • 619
