I'm using a seeeduino V4.0 and a CAN-BUS shield v2.0 with industrial grade SD card.
I'm using the default library given by the wiki of seeed.
I've simulate a can bus with two mcp2515. I can read it without trouble and everything is fine.
I can write/read on the SD card with the exemple given in the SD library.
But when I use this example, the can bus and SD card start without error. The can bus read normally and show the can bus data. But when I read the SD card, the file is created but completly empty. I've tried to modify to write on a .txt instead of .csv and when I try a
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile)
else
Serial.println("error: file not reachable");
The "myFile" return false.
ps: I don't ask a lot of question here. Sorry for bad formating my question.
