I have already connected succesfully the rfm69 on my Feather M0 Express... but I cannot do it again.
The connections are (in the order of the rfm69):
Vin -> 3V Gnd -> Gnd En -> (nothing) G0 -> 9 SCK -> SCK MISO -> MI MOSI -> MO CS -> 10 RST -> 6
The code of the setup is
#include <SPI.h>
#include <RH_RF69.h>
#define RFM69_CS 10
#define RFM69_INT 9
#define RFM69_RST 6
#define LED 13
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
void setup()
Serial.begin(9600);
while (!Serial);
Serial.println("Feather RFM69 RX Test!");
Serial.println();
// manual reset
digitalWrite(RFM69_RST, HIGH);
delay(10);
digitalWrite(RFM69_RST, LOW);
delay(10);
if (!rf69.init())
Serial.println("init failed");
else
Serial.println("init ok");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
// No encryption
if (!rf69.setFrequency(434.0))
Serial.println("setFrequency failed");
else
Serial.println("setFrequency ok");
// If you are using a high power RF69 eg RFM69HW, you must set a Tx power with the
// ishighpowermodule flag set like this:
//rf69.setTxPower(14, true);
// The encryption key has to be the same as the one in the client
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
rf69.setEncryptionKey(key);
#if 0
// For compat with RFM69 Struct_send
rf69.setModemConfig(RH_RF69::GFSK_Rb250Fd250);
rf69.setPreambleLength(3);
uint8_t syncwords[] = { 0x2d, 0x64 };
rf69.setSyncWords(syncwords, sizeof(syncwords));
rf69.setEncryptionKey((uint8_t*)"thisIsEncryptKey");
#endif
Serial.println("Fin du Setup");
But during the execution, the program stops at //**************************
I do not understand.
Can somebody help me?
Thanks a lot and merry Xmas
