I'm sending currently data from a Raspberry to an Arduino, but I have a problem with receiving response from the Arduino back to the Raspberry:
Sent the message: ['H', 'i', '.', '.', 'A', 'r', 'd', 'u', 'i', 'n', 'o', ' ', 'U', 'N', 'O', 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] Timed out.
Currently message received is in "got_time", so I see numerical value. When I change it to string I see "Hi..Arduino UNO" response. Problem is with timeout on the Raspberry. Raspberry sends message, Arduino receives it, Arduino should send confirmation of receipt of the message, Raspberry shows timeout of it. Can you guide me to the solution?
Arduino Nano code:
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
/****************** User Config *************************/
/* Set this radio as radio number 0 or 1 ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 /
RF24 radio(9,10);
const uint64_t addresses[2] = { 0xE1E2E3E4E5LL, 0xE6E7E8E9E0LL };
// byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0;
Serial.begin(115200);
printf_begin();
Serial.println(F("RF24/examples/GettingStarted"));
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
radio.begin();
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
radio.setPALevel(RF24_PA_LOW);
// radio.setRetries(15,15);
radio.setPayloadSize(32);
radio.setChannel(0x76);
// radio.setPALevel(RF24_PA_MIN);
// radio.setAutoAck(true);
// Open a writing and reading pipe on each radio, with opposite addresses
if (radioNumber) {
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
} else {
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
// Start the radio listening for data
radio.startListening();
radio.printDetails();
/****************** Ping Out Role *************************/
if (role == 1) { /* Not used in this case */ }
/**************** Pong Back Role ***************************/
if (role == 0) {
unsigned long got_time;
if(radio.available()) {
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &got_time, sizeof(unsigned long) ); // Get the payload
radio.stopListening(); // First, stop listening so we can talk
radio.write( &got_time, sizeof(unsigned long) ); // Send the final one back.
radio.startListening(); // Now, resume listening so we catch the next packets.
Serial.print(F("Sent response "));
Serial.println(got_time);
/****************** Change Roles via Serial Commands **************************/
/ Not used in this case */
} // Loop
Raspberry Pi 0 code:
import RPi.GPIO as GPIO # import gpio
import time #import time library
import spidev
from lib_nrf24 import NRF24 #import NRF24 library
GPIO.setmode(GPIO.BCM) # set the gpio mode
set the pipe address. this address shoeld be entered on the receiver alo
pipes = [[0xE1, 0xE2, 0xE3, 0xE4, 0xE5], [0xE6, 0xE7, 0xE8, 0xE9, 0xE0]]
radio = NRF24(GPIO, spidev.SpiDev()) # use the gpio pins
radio.begin(0, 25) # start the radio and set the ce,csn pin ce= GPIO08, csn= GPIO25
radio.setPayloadSize(32) #set the payload size as 32 bytes
radio.setChannel(0x76) # set the channel as 76 hex
radio.setDataRate(NRF24.BR_1MBPS) # set radio data rate
radio.setPALevel(NRF24.PA_MIN) # set PA level
radio.setAutoAck(True) # set acknowledgement as true
radio.enableDynamicPayloads()
radio.enableAckPayload()
radio.openWritingPipe(pipes[0]) # open the defined pipe for writing
radio.openReadingPipe(1,pipes[1]) # open the defined pipe for writing
radio.printDetails() # print basic detals of radio
time.sleep(3)
sendMessage = list("Hi..Arduino UNO") #the message to be sent
while len(sendMessage) < 32:
sendMessage.append(0)
try:
while True:
start = time.time() #start the time for checking delivery time
radio.write(sendMessage) # just write the message to radio
print("Sent the message: {}".format(sendMessage)) # print a message after succesfull send
radio.startListening() # Start listening the radio
while not radio.available(0):
time.sleep(1/100)
if time.time() - start > 2:
print("Timed out.") # print errror message if radio disconnected or not functioning anymore
break
radio.stopListening() # close radio
time.sleep(3) # give delay of 3 seconds
finally:
GPIO.cleanup() # this ensures a clean exit
Arduino console:
RF24/examples/GettingStarted *** PRESS 'T' to begin transmitting to the other node SPI Speedz = 10 Mhz STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0 RX_ADDR_P0-1 = 0xe6e7e8e9e0 0xe1e2e3e4e5 RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6 TX_ADDR = 0xe6e7e8e9e0 RX_PW_P0-6 = 0x10 0x10 0x00 0x00 0x00 0x00 EN_AA = 0x3f EN_RXADDR = 0x02 RF_CH = 0x76 RF_SETUP = 0x03 CONFIG = 0x0f DYNPD/FEATURE = 0x00 0x00 Data Rate = 1MBPS Model = nRF24L01+ CRC Length = 16 bits PA Power = PA_LOW ARC = 5 Sent response Hi..Arduino UNO Sent response Hi..Arduino UNO Sent response Hi..Arduino UNO Sent response Hi..Arduino UNO
Raspberry Pi 0 console:
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0 RX_ADDR_P0-1 = 0xe1e2e3e4e5 0xe6e7e8e9e0 RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6TX_ADDR = 0xe1e2e3e4e5 RX_PW_P0-6 = 0x10 0x10 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x76
RF_SETUP = 0x01
CONFIG = 0x0f
DYNPD/FEATURE = 0x3f 0x06
Data Rate = 1MBPS Model = nRF24l01+ CRC Length = 16 bits PA Power = PA_MIN Timed out. Timed out. Timed out.
