I am making a Christmas Tree with Arduino. I found a 12 led chaser code on internet so I made 12 rows of leds and hook them up to my Arduino pro mini. They are working just fine.
However, I also want to add music with piezo buzzer while running the LEDs. Is that possible somehow or should I use another microcontroller for piezo? I also used pin 10 for piezo buzzer and used pin 14(a0) for led assigned for pin 10 previously..
Here are the codes: 12 led chaser
#define t   30
#define t1  20
#define t2  100
#define t3  50
void setup() { // set up pins 2 to 13 as outputs for (int i = 2; i <= 13; i++) { pinMode(i, OUTPUT); } } /////////////////////////////////////////////////////////////////////////////////Effect 1 void loop(){
effect_1(); effect_1();
effect_2(); effect_2();
effect_3(); effect_3();
effect_4(); effect_4();
effect_5(); effect_5();
effect_6(); effect_6();
effect_7(); effect_7(); } //left to right and right to left void effect_1() { for(int i=2; i<14; i++){ digitalWrite(i, HIGH); delay(t1); digitalWrite(i+1, HIGH); delay(t1); digitalWrite(i+2, HIGH); delay(t1); digitalWrite(i, LOW); delay(t1); digitalWrite(i+1, LOW); delay(t1); } for(int i=13; i>1; i--){ digitalWrite(i, HIGH); delay(t1); digitalWrite(i-1, HIGH); delay(t1); digitalWrite(i-2, HIGH); delay(t1); digitalWrite(i, LOW); delay(t1); digitalWrite(i-1, LOW); delay(t1); } } /////////////////////////////////////////////////////////////////////////////////Effect 2 void effect_2() { int count = 13; // keeps track of second LED movement
// move first LED from left to right and second from right to left for (int i = 2; i < 13; i++) { clear(); digitalWrite(i, HIGH); // chaser 1 digitalWrite(count, HIGH); // chaser 2 count--; // stop LEDs from appearing to stand still in the middle if (count != 7) { delay(t2); } }
// move first LED from right to left and second LED from left to right for (int i = 13; i > 2; i--) { clear(); digitalWrite(i, HIGH); // chaser 1 digitalWrite(count, HIGH); // chaser 2 count++; // stop LEDs from appearing to stand still in the middle if (count != 8) { delay(t2); } } }
////////////////////////////////////////////////////////////////////////////////Effect 3
void effect_3() { for(int i=2; i<14; i++){ digitalWrite(i, HIGH); delay(t3); } for(int i=2; i<14; i++){ digitalWrite(i, LOW); delay(t3); }
for(int i = 14; i>=2; i--){ digitalWrite(i, HIGH); delay(t3); } for(int i = 14; i>=2; i--){ digitalWrite(i, LOW); delay(t3); } } ///////////////////////////////////////////////////////////////////////////Effect 4 void effect_4() { for(int j = 2; j <= 13; j++){ digitalWrite(j, HIGH); delay(t2); j=j+1; } for(int j = 2; j <= 13; j++){ digitalWrite(j, LOW); delay(t2); }
for(int k = 15; k > 2; k--){ digitalWrite(k, HIGH); delay(t2); k=k-1; } for(int k = 15; k > 2; k--){ digitalWrite(k, LOW); delay(t2); } } //////////////////////////////////////////////////////////////////////////////Effect 5 void effect_5() { for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin, HIGH); delay(t1); digitalWrite(pin+1, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+1, HIGH); delay(t1); digitalWrite(pin+2, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+2, HIGH); delay(t1); digitalWrite(pin+3, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+3, HIGH); delay(t1); digitalWrite(pin+4, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+4, HIGH); delay(t1); digitalWrite(pin+5, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+5, HIGH); delay(t1); digitalWrite(pin+6, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+6, HIGH); delay(t1); digitalWrite(pin+7, LOW); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin+7, HIGH); delay(t1); digitalWrite(pin+8, LOW); delay(t1); } for(int pin = 9; pin >= 2; pin--) { digitalWrite(pin+8, HIGH); delay(t1); digitalWrite(pin+9, LOW); delay(t1); } for(int pin = 9; pin >= 2; pin--) { digitalWrite(pin+9, HIGH); delay(t1); digitalWrite(pin+10, LOW); delay(t1); } for(int pin = 9; pin >= 2; pin--) { digitalWrite(pin+10, HIGH); delay(t1); digitalWrite(pin+11, LOW); delay(t1); } for(int pin = 14; pin >= 2; pin--) { digitalWrite(pin+11, HIGH); delay(t1); } for(int pin = 13; pin >= 2; pin--) { digitalWrite(pin, LOW); delay(t1); } } /////////////////////////////////////////////////////////////////////////////Effect 6 void effect_6() { for(int j=2; j<14; j++){ digitalWrite(j, LOW); delay(t); digitalWrite(j, HIGH); delay(t); digitalWrite(j-2, LOW); delay(t); digitalWrite(j, HIGH); } for(int k = 15; k>2; k--){ digitalWrite(k, LOW); delay(t); digitalWrite(k, HIGH); delay(t); digitalWrite(k+2, LOW); delay(t); digitalWrite(k, HIGH); } for(int k = 2; k<14; k++){ digitalWrite(k, LOW); delay(t); digitalWrite(k, HIGH); delay(t); digitalWrite(k-2, LOW); delay(t); digitalWrite(k, HIGH); } for(int k = 15; k>2; k--){ digitalWrite(k, LOW); delay(t); digitalWrite(k, HIGH); delay(t); digitalWrite(k+4, LOW); delay(t); digitalWrite(k, HIGH); } for(int k = 2; k<14; k++){ digitalWrite(k, LOW); delay(t); digitalWrite(k, HIGH); delay(t); digitalWrite(k-4, LOW); delay(t); digitalWrite(k, HIGH); } } ///////////////////////////////////////////////////////////////////////////////////Effect 7 void effect_7() { for(int j=2; j<14; j++){ digitalWrite(j, HIGH); delay(t); digitalWrite(j+2, LOW); delay(t); } for(int k = 15; k>2; k--){ digitalWrite(k, HIGH); delay(t); digitalWrite(k+2, LOW); delay(t); } }
// function to switch all LEDs off void clear(void) { for (int i = 2; i <= 13; i++) { digitalWrite(i, LOW); } }
Melody tone for buzzer:
  We Wish You a Merry Christmas - Traditional Christmas song
  Connect a piezo buzzer or speaker to pin 11 or select a new pin.
  More songs available at https://github.com/robsoncouto/arduino-songs
                                          Robson Couto, 2019
*/ #define NOTE_B0 31 #define NOTE_C1 33 #define NOTE_CS1 35 #define NOTE_D1 37 #define NOTE_DS1 39 #define NOTE_E1 41 #define NOTE_F1 44 #define NOTE_FS1 46 #define NOTE_G1 49 #define NOTE_GS1 52 #define NOTE_A1 55 #define NOTE_AS1 58 #define NOTE_B1 62 #define NOTE_C2 65 #define NOTE_CS2 69 #define NOTE_D2 73 #define NOTE_DS2 78 #define NOTE_E2 82 #define NOTE_F2 87 #define NOTE_FS2 93 #define NOTE_G2 98 #define NOTE_GS2 104 #define NOTE_A2 110 #define NOTE_AS2 117 #define NOTE_B2 123 #define NOTE_C3 131 #define NOTE_CS3 139 #define NOTE_D3 147 #define NOTE_DS3 156 #define NOTE_E3 165 #define NOTE_F3 175 #define NOTE_FS3 185 #define NOTE_G3 196 #define NOTE_GS3 208 #define NOTE_A3 220 #define NOTE_AS3 233 #define NOTE_B3 247 #define NOTE_C4 262 #define NOTE_CS4 277 #define NOTE_D4 294 #define NOTE_DS4 311 #define NOTE_E4 330 #define NOTE_F4 349 #define NOTE_FS4 370 #define NOTE_G4 392 #define NOTE_GS4 415 #define NOTE_A4 440 #define NOTE_AS4 466 #define NOTE_B4 494 #define NOTE_C5 523 #define NOTE_CS5 554 #define NOTE_D5 587 #define NOTE_DS5 622 #define NOTE_E5 659 #define NOTE_F5 698 #define NOTE_FS5 740 #define NOTE_G5 784 #define NOTE_GS5 831 #define NOTE_A5 880 #define NOTE_AS5 932 #define NOTE_B5 988 #define NOTE_C6 1047 #define NOTE_CS6 1109 #define NOTE_D6 1175 #define NOTE_DS6 1245 #define NOTE_E6 1319 #define NOTE_F6 1397 #define NOTE_FS6 1480 #define NOTE_G6 1568 #define NOTE_GS6 1661 #define NOTE_A6 1760 #define NOTE_AS6 1865 #define NOTE_B6 1976 #define NOTE_C7 2093 #define NOTE_CS7 2217 #define NOTE_D7 2349 #define NOTE_DS7 2489 #define NOTE_E7 2637 #define NOTE_F7 2794 #define NOTE_FS7 2960 #define NOTE_G7 3136 #define NOTE_GS7 3322 #define NOTE_A7 3520 #define NOTE_AS7 3729 #define NOTE_B7 3951 #define NOTE_C8 4186 #define NOTE_CS8 4435 #define NOTE_D8 4699 #define NOTE_DS8 4978 #define REST 0
// change this to make the song slower or faster int tempo = 140;
// change this to whichever pin you want to use int buzzer = 11;
// notes of the moledy followed by the duration. // a 4 means a quarter note, 8 an eighteenth , 16 sixteenth, so on // !!negative numbers are used to represent dotted notes, // so -4 means a dotted quarter note, that is, a quarter plus an eighteenth!! int melody[] = {
// We Wish You a Merry Christmas // Score available at https://musescore.com/user/6208766/scores/1497501
NOTE_C5,4, //1 NOTE_F5,4, NOTE_F5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,8, NOTE_D5,4, NOTE_D5,4, NOTE_D5,4, NOTE_G5,4, NOTE_G5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,4, NOTE_C5,4, NOTE_C5,4, NOTE_A5,4, NOTE_A5,8, NOTE_AS5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,4, NOTE_D5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4,
NOTE_F5,2, NOTE_C5,4, //8 NOTE_F5,4, NOTE_F5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,8, NOTE_D5,4, NOTE_D5,4, NOTE_D5,4, NOTE_G5,4, NOTE_G5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,4, NOTE_C5,4, NOTE_C5,4, NOTE_A5,4, NOTE_A5,8, NOTE_AS5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,4, NOTE_D5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, NOTE_C5,4,
NOTE_F5,4, NOTE_F5,4, NOTE_F5,4,//17 NOTE_E5,2, NOTE_E5,4, NOTE_F5,4, NOTE_E5,4, NOTE_D5,4, NOTE_C5,2, NOTE_A5,4, NOTE_AS5,4, NOTE_A5,4, NOTE_G5,4, NOTE_C6,4, NOTE_C5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, NOTE_C5,4, NOTE_F5,4, NOTE_F5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,8, NOTE_D5,4, NOTE_D5,4, NOTE_D5,4,
NOTE_G5,4, NOTE_G5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,8, //27 NOTE_E5,4, NOTE_C5,4, NOTE_C5,4, NOTE_A5,4, NOTE_A5,8, NOTE_AS5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,4, NOTE_D5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, NOTE_C5,4, NOTE_F5,4, NOTE_F5,4, NOTE_F5,4, NOTE_E5,2, NOTE_E5,4, NOTE_F5,4, NOTE_E5,4, NOTE_D5,4,
NOTE_C5,2, NOTE_A5,4,//36 NOTE_AS5,4, NOTE_A5,4, NOTE_G5,4, NOTE_C6,4, NOTE_C5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, NOTE_C5,4, NOTE_F5,4, NOTE_F5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,8, NOTE_D5,4, NOTE_D5,4, NOTE_D5,4, NOTE_G5,4, NOTE_G5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,4, NOTE_C5,4, NOTE_C5,4,
NOTE_A5,4, NOTE_A5,8, NOTE_AS5,8, NOTE_A5,8, NOTE_G5,8,//45 NOTE_F5,4, NOTE_D5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, NOTE_C5,4, NOTE_F5,4, NOTE_F5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,8, NOTE_D5,4, NOTE_D5,4, NOTE_D5,4, NOTE_G5,4, NOTE_G5,8, NOTE_A5,8, NOTE_G5,8, NOTE_F5,8, NOTE_E5,4, NOTE_C5,4, NOTE_C5,4,
NOTE_A5,4, NOTE_A5,8, NOTE_AS5,8, NOTE_A5,8, NOTE_G5,8, //53 NOTE_F5,4, NOTE_D5,4, NOTE_C5,8, NOTE_C5,8, NOTE_D5,4, NOTE_G5,4, NOTE_E5,4, NOTE_F5,2, REST,4 };
// sizeof gives the number of bytes, each int value is composed of two bytes (16 bits) // there are two values per note (pitch and duration), so for each note there are four bytes int notes = sizeof(melody) / sizeof(melody[0]) / 2;
// this calculates the duration of a whole note in ms int wholenote = (60000 * 4) / tempo;
int divider = 0, noteDuration = 0;
void setup() { // iterate over the notes of the melody. // Remember, the array is twice the number of notes (notes + durations) for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
// calculates the duration of each note
divider = melody[thisNote + 1];
if (divider &gt; 0) {
  // regular note, just proceed
  noteDuration = (wholenote) / divider;
} else if (divider &lt; 0) {
  // dotted notes are represented with negative durations!!
  noteDuration = (wholenote) / abs(divider);
  noteDuration *= 1.5; // increases the duration in half for dotted notes
// we only play the note for 90% of the duration, leaving 10% as a pause
tone(buzzer, melody[thisNote], noteDuration * 0.9);
// Wait for the specief duration before playing the next note.
delay(noteDuration);
// stop the waveform generation before the next note.
noTone(buzzer);
void loop() { // no need to repeat the melody. }
the busybee
  • 2,408
I think the method suggested by chrisl is probably the best for you to use here. If you want to make a more-conventional multitasking system, you would set a timer such as TIMER2 to the minimum time slice, then at the start of your code (after setup) you'd have something like this:
ISR(TIMER2_COMPA_vect) { myIntHandler(); }
Here myIntHandler() does whatever needs to get done on each tick of TIMER2. I use this general approach in my open-source DaqPort code to do simultaneous oscilloscope data acquisition and signal generation, while still handling serial commands in the background. But that's probably overkill for your project. You can find out more about DaqPort at https://www.daqarta.com/dw_rraa.htm
Boggyman
  • 619
