SOLVED! See bottom.
I know this question has been asked a lot (believe me, I've been Googling for solutions for 3 days, and have come across many posts on SE), but none of the posts I've found have solved my issue. Much of the problem, I think, is many of the solutions are several years old and discuss options either no longer available in the IDE, or no longer valid for the hardware.
I have an ATmega328P-PU on a breadboard. Largely following this guide, I hooked it up like this in order to burn the bootloader.
Bootloader Schematic
I uploaded the "Arduino ISP" sketch from Examples to my Uno, and selected "Arduino as ISP" as the programmer. I tried selecting "Arduino Duemilanove or Nano w/ ATmega328" from the boards menu (per the guide), but the option no longer exists in standard install of IDE v.1.8.13. I tried "Arduino Duemilanove or Diecimila", as well as "Arduino Nano" as boards, both with "ATmega328P" as the processor (and, in the case of Arduino Nano, also tried "ATmega328P (Old bootloader)", as mentioned several times). All failed.
I finally found a reference to the MiniCore board library, installed it, selected "ATmega328", with "External 16 MHz" for the clock, and was finally able to burn the bootloader.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\<username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0b11111101:m -Uhfuse:w:0b11011110:m -Ulfuse:w:0b11110111:m
avrdude: Version 6.3-20190619 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is &quot;C:\Users\&lt;username&gt;\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/avrdude.conf&quot;
     Using Port                    : COM3
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : STK500
     Description     : Atmel STK500 Version 1.x firmware
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e950f (probably m328p) avrdude: erasing chip avrdude: reading input file "0x3f" avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x3f: avrdude: load data lock data from input file 0x3f: avrdude: input file 0x3f contains 1 bytes avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ... avrdude: 1 bytes of lock verified avrdude: reading input file "0b11111101" avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written avrdude: verifying efuse memory against 0b11111101: avrdude: load data efuse data from input file 0b11111101: avrdude: input file 0b11111101 contains 1 bytes avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ... avrdude: 1 bytes of efuse verified avrdude: reading input file "0b11011110" avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.05s
avrdude: 1 bytes of hfuse written avrdude: verifying hfuse memory against 0b11011110: avrdude: load data hfuse data from input file 0b11011110: avrdude: input file 0b11011110 contains 1 bytes avrdude: reading on-chip hfuse data:
avrdude: verifying ... avrdude: 1 bytes of hfuse verified avrdude: reading input file "0b11110111" avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written avrdude: verifying lfuse memory against 0b11110111: avrdude: load data lfuse data from input file 0b11110111: avrdude: input file 0b11110111 contains 1 bytes avrdude: reading on-chip lfuse data:
avrdude: verifying ... avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/bootloaders/optiboot_flash/bootloaders/atmega328p/16000000L/optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex:i -Ulock:w:0x0f:m
     Using Port                    : COM3
     PAGEL                         : PD7
     BS2                           : PC2
     RETRY pulse                   : SCK
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
     Hardware Version: 2
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: Device signature = 0x1e950f (probably m328p) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "C:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/bootloaders/optiboot_flash/bootloaders/atmega328p/16000000L/optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex" avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% -0.00s
avrdude: 32768 bytes of flash written avrdude: verifying flash memory against C:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/bootloaders/optiboot_flash/bootloaders/atmega328p/16000000L/optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex: avrdude: load data flash data from input file C:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/bootloaders/optiboot_flash/bootloaders/atmega328p/16000000L/optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex: avrdude: input file C:\Users&lt;username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/bootloaders/optiboot_flash/bootloaders/atmega328p/16000000L/optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex contains 32768 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% -0.00s
avrdude: verifying ... avrdude: 32768 bytes of flash verified avrdude: reading input file "0x0f" avrdude: writing lock (1 bytes):
avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x0f: avrdude: load data lock data from input file 0x0f: avrdude: input file 0x0f contains 1 bytes avrdude: reading on-chip lock data:
So I then reconfigured the breadboard. I do not have an Uno with a removable ATmega, so I am using an FTDI break-out board instead, wiring like so
Programming Configuration
Selected the same "ATmega328" from the MiniCore library (actually, I tried nearly every board on the list in desperation), and still get the "programmer is not responding" error until the IDE gives up.
Sketch uses 1030 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\<username>\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.0.8/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\<username>\AppData\Local\Temp\arduino_build_929593/Blink.ino.hex:i
     Using Port                    : COM7
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x30
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I've uninstalled and reinstalled the USB/FTDI drivers, I've tried two different FTDI boards, I've even tried the "Minimal Circuit" described in the guide (removing the oscillator, capacitors, and the pull-up resistor, and installed/selected the "ATmega328 on a breadboard" board), nothing seems to work. It also seemed odd that TX pin on the Arduino/FTDI was going the the TX pin on the ATmega, so I even tried switching TX and RX. Same error.
Also scrapped everything and tried following this video (and subsequent webpage guide), which makes it look so simple, with a 100nF capacitor in place of the pull-up resistor on the Mega's reset pin. Same error.
I'm truly at wit's end. Does anyone have any additional pointers that are current?
T(LOADS!)IA
EDIT: include photo of breadboard as requested.
Programming Breadboard
EDIT #2: deleted resistor, added 100nF cap on DTR pin.
Programming Breadboard w/Cap on DTR
EDIT #3: updated wiring including cap and resistor on DTR
Programming Breadboard w/Cap & Resistor on DTR
UPDATE: I solved the issue with lots of help from timemage. I had pulled the ATmega from another project that had already set the chip to use the 8MHz internal clock. So I had to rewire the board as the first schematic, with the 16MHz external crystal still installed, then re-burn the bootloader making sure to select "Internal 8MHz" from the Clock options of the MiniCore board. Once the bootloader was re-flashed, I could then re-wire the board according to the second schematic only with the 16MHz crystal and the 20nF caps removed, and the FTDI board was then able to upload sketches.
BIG shout out to timemage, who sat in chat with me for over an hour trying to figure it out.
UPDATE #2: the FTDI board I was using - the DFRobot USB2Serial Light (DFR0164) - actually has the pins mislabelled (or, rather, not labelled as expected). The TX pin actually does get wired to the TX pin of the ATMega, and the RX pin goes to the RX pin of the ATmega.
Carl S
