I was trying to use nodemcu for a project. No issues when uploading the OTA sample code. Added led blink to test. But when trying to upload the second sketch via OTA getting an error
no response from device.
Tried ping to the Nodemcu IP and no issue there. Have the OTA codes in both sketch. When trying to upload the 2nd second, the led blink will stop for 2,3 seconds and resumes the normal blinking, gets an error in ide after.
How to check if there is any firewall issue?
IDE settings
Attaching code below
const char* ssid = STASSID;
const char* password = STAPSK;
void setup() { Serial.begin(9600); pinMode(LED_BUILTIN, OUTPUT);
Serial.println("Booting"); WiFi.mode(WIFI_STA); WiFi.begin(ssid, password); while (WiFi.waitForConnectResult() != WL_CONNECTED) { Serial.println("Connection Failed! Rebooting..."); delay(5000); ESP.restart(); }
// Port defaults to 8266 // ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID] // ArduinoOTA.setHostname("myesp8266");
// No authentication by default // ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well // MD5(admin) = 21232f297a57a5a743894a0e4a801fc3 // ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart( { String type; if (ArduinoOTA.getCommand() == U_FLASH) { type = "sketch"; } else { // U_FS type = "filesystem"; }
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
}); ArduinoOTA.onEnd( { Serial.println("\nEnd"); }); ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) { Serial.printf("Progress: %u%%\r", (progress / (total / 100))); }); ArduinoOTA.onError([](ota_error_t error) { Serial.printf("Error[%u]: ", error); if (error == OTA_AUTH_ERROR) { Serial.println("Auth Failed"); } else if (error == OTA_BEGIN_ERROR) { Serial.println("Begin Failed"); } else if (error == OTA_CONNECT_ERROR) { Serial.println("Connect Failed"); } else if (error == OTA_RECEIVE_ERROR) { Serial.println("Receive Failed"); } else if (error == OTA_END_ERROR) { Serial.println("End Failed"); } }); ArduinoOTA.begin(); Serial.println("Ready"); Serial.print("IP address: "); Serial.println(WiFi.localIP()); }
void loop() { ArduinoOTA.handle();
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level delay(100); // Wait for a second digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH delay(100);
Serial.println("Looping"); }
Anandu v t
