I want to make an Http Post request with Bearer Authentication to my api using my Arduino Mkr Wifi 1010, but I couldn't find the appropriate library to do something like this (code generated with one made with Postman):
    POST /api/v1/rilevamento/transaction/commit HTTP/1.1
Host: www.....:8082
Authorization: Bearer eyJhb.......
Content-Type: application/json
Content-Length: 233
{ "id": 0, "dispositivo": "sesto", "nomeutente": "MyName", "cognomeutente": "MySurname", "mailutente": "name@email.it", "data": "2020-11-23T09:23:03.142+00:00", "temperatura": 37.5 }
Can you tell me where to find this library? I tried WifiNiNa httpClient, ArduinoHttpClient, HTTPClient and other but I couldn't get any response or even enter in the method of my api on debug.
Riccardo
  • 33
The "Authorization" is simply an HTTP header. So add it in your request like:
http.addHeader("Authorization", token);
The value of "token" is just the string "Bearer " followed by your authorization string. Don't neglect the SPACE after the word "Bearer". It will look like:
"Bearer eyJhb......"
On the Arduino MKR WiFi 1010 you use the WiFiNINA library which is slightly different. Here is some example code:
  if (client.connect(server, 80)) {
    client.println("POST /test/post.php HTTP/1.1");
    client.println("Host: www.targetserver.com");
    client.println(authorizationHeader);
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.print("Content-Length: ");
    client.println(postData.length());
    client.println();
    client.print(postData);
The variable authorizationHeader will have the "Authorization: Bearer xxxxx...." authorization string.
Or you can replace the client.println(authorizationHeader); by:
client.print("Authorization: Bearer ");
client.print(token);
to avoid dealing with concatenations, etc.
client can be an instance of WiFiSSLClient which works with both WiFi101 and WiFiNINA.
Eugenio Pace
  • 296
jwh20
  • 1,045
