I think this is my last post about this specific project, but I got a really weird curveball right now
I managed to do the webpage I wanted, and pass the string along. Now, when a LED lights up, it sends the corresponding letter to the LCD.
The problem now is that somehow, when I send a long string, the LCD somehow "knows" and display the overflow on the second row, which makes no sense to me. All I can think of is that the Ethernet Shield is using the same connections as my I2C that connects to the LCD.
That being said, here is my code:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <SPI.h>
#include <Ethernet.h>
#define latchPin 5
#define clockPin 7
#define dataPin 6
LiquidCrystal_I2C lcd(0x27,16,2);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server(80);
String text;
char readHttp[100];
int i;
boolean temtexto;
char lcdtext[16];
Serial.begin(9600);
for (int i = 2; i < 7; i++) {
if (i != 4) {
pinMode(i, OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
lcd.init();
lcd.setBacklight(HIGH);
lcd.setCursor(0,0);
lcd.print("INICIANDO");
Serial.println("Iniciando");
if (Ethernet.begin(mac) == 0) {
lcd.clear();
lcd.setCursor(1,0);
lcd.print("FALHA AO PEGAR");
Serial.println("FALHA");
lcd.setCursor(7,1);
lcd.print("IP");
delay(5000);
return;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PRONTO");
lcd.setCursor(0,1);
lcd.print(Ethernet.localIP());
lcd.setCursor(0,0);
Serial.println(Ethernet.localIP());
server.begin();
brilho(255);
inicializationEffect();
void loop(){
EthernetClient client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
lcd.setBacklight(LOW);
lcd.clear();
char c = client.read();
if (c == ';') { temtexto = false; readHttp[i] = '\n';}
if (temtexto) {
if(i < 100) {
readHttp[i] = toupper(c);
i++;
if (c == '?') { temtexto = true; }
if (c == '\n') {
client.println("HTTP/1.1 200 OK"); // Envia nova pagina
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Parede Stranger Things</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Qual texto deseja enviar?</H1>");
client.println("<input type=text id=texto style=width:295px maxlength=50><br>");
client.println("<input type=submit value='Enviar' style=width:150px;height:45px onClick=location.href='/?'+document.getElementById('texto').value+';'>");
client.println("</BODY>");
client.println("</HTML>");
client.println("<string>");
client.println("</string>");
delay(1);
client.stop();
char *leader = readHttp;
char *follower = leader;
// While we're not at the end of the string (current character not NULL)
while (*leader) {
// Check to see if the current character is a %
if (*leader == '%') {
// Grab the next two characters and move leader forwards
leader++;
char high = *leader;
leader++;
char low = *leader;
// Convert ASCII 0-9A-F to a value 0-15
if (high > 0x39) high -= 7;
high &= 0x0f;
// Same again for the low byte:
if (low > 0x39) low -= 7;
low &= 0x0f;
// Combine the two into a single byte and store in follower:
*follower = (high << 4) | low;
} else {
// All other characters copy verbatim
*follower = *leader;
// Move both pointers to the next character:
leader++;
follower++;
// Terminate the new string with a NULL character to trim it off
*follower = 0;
lcd.clear();
executeEffect(readHttp);
memset(readHttp, 0, sizeof readHttp);
i = 0;
void lineActivation(int line, int keepalive) {
if (keepalive == 0) {
for (int i = 2; i <= 4; i++) {
if (i == 4) { i = 8; } //porta 4 usada pelo SD do Ethernet
digitalWrite(i, LOW);
if (line >= 1 && line <=3){
if (line == 3) { line = 7; } //porta 4 usada pelo SD do Ethernet
digitalWrite(line+1, HIGH); //coloca a linha 1 em estado lógico alto
void activateLetter(char letter, int on, int off) {
int lt;
lt = (((int)letter - 64) % 9);
if (((int)letter - 64) > 8) {
lt = lt + 1;
if (on) {
callCol(1<<lt-1);
delay(on);
if (off) {
callCol(0);
delay(off);
void callCol(int col){
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, highByte(col));
shiftOut(dataPin, clockPin, MSBFIRST, lowByte(col));
digitalWrite(latchPin, HIGH);
void executeEffect(char text[]) {
if (strlen(text) > 0) {
brilho(255);
memset(lcdtext, ' ', sizeof lcdtext);
for (int i = 0; i < strlen(text); i++) {
if (text[i] == ' ') {
lcdScreen(' ');
delay(1000);
} else if (((int)text[i] < -58 && (int)text[i] > -65) || ((int)text[i] < -28 && (int)text[i] > -33)) {
text[i] = 'A';
} else if (((int)text[i] < -47 && (int)text[i] > -41) || ((int)text[i] < -9 && (int)text[i] > -14)) {
text[i] = 'O';
} else if (((int)text[i] < -52 && (int)text[i] > -57) || ((int)text[i] < -20 && (int)text[i] > -25)) {
text[i] = 'E';
} else if (((int)text[i] < -49 && (int)text[i] > -53) || ((int)text[i] < -16 && (int)text[i] > -21)) {
text[i] = 'I';
} else if (((int)text[i] < -35 && (int)text[i] > -40) || ((int)text[i] < -3 && (int)text[i] > -8)) {
text[i] = 'U';
} else if (((int)text[i] == -25 || (int)text[i] == -57)) {
text[i] = 'C';
if ((int)text[i] < 65 or (int)text[i] > 90) {
} else {
lineActivation(int(((int)text[i] - 64) / 9) + 1, 0);
//Serial.println(text[i]);
lcdScreen(text[i]);
activateLetter(text[i], 1000, 200);
for (int i = 0; i < 16; i++){
lcdScreen(' ');
delay(500);
lcd.clear();
void lcdScreen(char ltc) {
Serial.println(ltc);
memcpy(lcdtext, &lcdtext[1], sizeof(lcdtext) - sizeof(char));
lcdtext[15] = ltc;
lcd.setCursor(0,0);
lcd.print(lcdtext);
void inicializationEffect() {
Serial.println("LineByLine");
for (int i = 1; i < 27; i++) {
lineActivation(int(i / 9) + 1, 0);//ativa a linha
activateLetter(char(64 + i), 100, 10); //ativa a letra
void waveEffect() {
Serial.println("Wave");
for (int i = 1; i < 4; i++) {
lineActivation(i, 1);//ativa a linha
for (int i = 1; i < 10; i++) {
activateLetter(char(72 + i), 100, 0);
activateLetter(char(72 + i), 0, 100);
lineActivation(0, 0);
void blink() {
Serial.println("Blink");
callCol(511);
lineActivation(1,1);
lineActivation(2,1);
lineActivation(3,1);
for (int i = 0; i < 256; i++){
brilho(i);
delay(1);
delay(100);
for (int i = 255; i >= 0; i--){
brilho(i);
delay(1);
void brilho(byte brt) {
analogWrite(9, 255-brt);
I am using a W5100 Ethernet Shield, a I2C to LCD adapter and a 16x2 LCD. The I2C is connected to the pins A4(SDA) and A5(SCL).
Here is a picture of how the LCD appears when I send "This is a really long string":
On the first line the text scrolls, one character at a time, as intended. However, on the second line there is an overflow of the text that, as far as I can tell, I never sent to the LCD in the first place. Even if I try to lcd.clear() after every character sent, it still persists with the end of the string on the second line.
