I am using sim 800l with arduino. I am successfully sending AT command from arduino, not in serial monitor but I am unable to catch the response after each successful command execution if its ok or not. I want to do that because, if there is an error in a certain command the next command will not be executed unless its successful. Can you tell me is there any way to do so?
Asked
Active
Viewed 677 times
for a polling serial read I use this method :
bool tSim8_sendCommand(uint8_t sim_cmd[])
uint8_t simOK[2] = {0}, i=20;
tSoftSerial1_write(sim_cmd);
tSoftSerial1_write("\r\n");
while (i--)
simOK[0] = simOK[1];
simOK[1] = tSoftSerial1_readChar();
if(simOK[0] == 'O' || simOK[1] =='K')
return true;
return false;
the variable i i the while loop, is used just for retries, so the program doesn't get trapped in an infinite loop. the code is self-explanatory. the incoming characters are "pushed" into an array till the array reads "OK".
for a non-blocking one, it's a bit complicated as you have to define state-machines and concurret loops. here is a method I use for finding out if the last transmission was OK:
void tsim_phase_ok_routine(uint8_t inChar)
if(tsim_aux_buff[0] == 'O' && tsim_aux_buff[1] =='K' && tsim_aux_buff[2] =='\r')
tsim_status_flag |= (1<<PHASE_OK);
tsim_status_flag &=~(1<<PHASE_CON_ERR);
return;
else
tsim_aux_buff[0] = tsim_aux_buff[1];
tsim_aux_buff[1] = tsim_aux_buff[2];
tsim_aux_buff[2] = inChar;
err_timeout--;
if(!(tsim_status_flag & (1<<PHASE_OK)) && !err_timeout)
tsim_status_flag &=~(1<<PHASE_OK);
tsim_status_flag |= (1<<PHASE_CON_ERR);
I define "PHASES" to find out which phase is sim800 in. the whole function would be written in RX interrupt service routine and the input character would be fed to it.
Tirdad the Whitehand
- 559
- 2
- 6
