I need to reproduce with a digital pin of an Arduino such a key in the form of a sequence of 1's and 0's, where a one takes 2 ms high and 2 ms low, and a zero takes 1 ms high and 1 ms low. enter image description here
  int key = 0b101100001111;
void setup() { pinMode(13, OUTPUT); }
void loop() { for (int n = 0; n < 12; n++) { if (bitRead(key, n) == 1) //execute if bit value == 1 { sendSignal(2000); }
else //execute if bit value == 0
  sendSignal(1000);
void sendSignal(int duration) { digitalWrite(13, HIGH); delayMicroseconds(duration); digitalWrite(13, LOW); delayMicroseconds(duration); }
This sketch really works! I figured out what my problem is: I actually need a longer key (64 bits). I am using long type: long key = 0b1000011110001101111100011111001010110001101101111011011100110100; but long only allows 32 bits. What do you recommend to do? Maybe you need to arrange it as an array? I think you can make it easier somehow. thank you
Антон
  • 265
You should make
byte key = 0b101100001111;
global, i.e. put it BEFORE the setup function and not within it.
Also, a byte only can contain 8 bits, you need 12, so make it an int (thanks to ocrdu, see comment below):
If you need more bits, you can use uint32_t or uint64_t, and count further than the current 12.
Now key is a local variable which is removed after exiting the setup function.
I'm not sure where 'key' comes from in:
switch (bitRead(key, n)) {
Do you get a compiler error, or did you ALSO define a global variable named key ? Anyway, if you make key global it will fix either way.
A few other remarks:
  • Try to align your parenthesis, like the 3 }'s at the end, indent them properly, this makes your code much more readable
  • Instead of the switch/case, you could use an if statement in this case, as the re are only (and always) two possible values (0 and 1):
Thus:
 if(bitRead(key, n) == 0)
 else // 1
  • Try also comments to write in English instead of Greek, you never know when your comments will be read by non Greek readers (like now).
  • You can make the following fragment shorter and less duplicated:
Original:
delayMicroseconds(1000);
If you wrap this in a function:
Then you can write a 1 by calling:
sendSignal(2000);
and a 0 by calling:
sendSignal(1000);
ocrdu
  • 1,795
Michel Keijzers
  • 13,014
  • 41
  • 58
If you modify the code slightly, you can use an array of characters of any length, so need to worry about digital word length.
Here's a modified version of your program that does this.
Note that I also took the liberty of replacing the 'magic number' 13 with LED_PIN, and the 'magic number' 12 with KEY_LEN. I would suggest you do the same with your pulsewidth values - maybe something like PULSE_WIDTH_ONE_USEC and PULSE_WIDTH_ZERO_USEC? That way someone else (or you 3 months later) looking at your code can easily see what the values are intended to do
const int KEY_LEN = 62;
const char key[KEY_LEN] = { "10110110110101111001011010110100101011011100110110101101101100" };
const int LED_PIN = 13;
//int key = 0b101100001111; void setup() { Serial.begin(115200); pinMode(13, OUTPUT); }
void loop() { for (int n = 0; n < KEY_LEN; n++) { if (key[n]== '1') //execute if bit value == 1 { Serial.print("1"); sendSignal(200); }
else if (key[n] == '0')//execute if bit value == 0
  Serial.print(&quot;0&quot;);
  sendSignal(100);
else
  Serial.print(&quot;x&quot;);
} Serial.println(); }
void sendSignal(int duration) { digitalWrite(LED_PIN, HIGH); //delayMicroseconds(duration); delay(duration); digitalWrite(LED_PIN, LOW); //delayMicroseconds(duration); delay(duration); }
starship15
  • 782
