I wanted to make a buzzer go off when the distance measured by the ultrasonic sensor becomes more than 100cm. The things used in this project are a 4x4 keypad, an hc-sr04 ultrasonic sensor, and a passive buzzer all connected to a keyestudio mega 2560.
What happens is that the moment I upload the code/turn on the Arduino, the buzzer turns on despite a solid object being within a 100cm range. And the buzzer almost randomly stops for a couple of seconds and continues. It won't turn off, even when I press the appropriate key on the keypad.
This is the code I have written, thanks
#include <Key.h>
#include <Keypad.h>
const int trigPin = 11; //output to sensor
const int echoPin = 12; //input from sensor
const int buzzPin = 13; //output to buzzer
const byte ROWS = 4;
const byte COLS = 4;
long duration; //travel time of sound waves
int distance; //distance at which an object is
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9,8,7,6};
byte colPins[COLS] = {5,4,3,2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzPin, OUTPUT);
Serial.begin(9600);
// put your main code here, to run repeatedly:
char customKey = customKeypad.getKey(); // gets key values from keypad
if(customKey) {
Serial.println(customKey);
digitalWrite(trigPin, LOW); //reset the sensor by turning it off for 2 microseconds
delayMicroseconds(5);
digitalWrite(trigPin, HIGH); //generate ultrasound wave by turning it on for 10 microseconds
delayMicroseconds(50);
duration = pulseIn(echoPin, HIGH); //time it takes for sound to get back
distance = duration*0.034/2; //plug into formula for distance
Serial.println(distance);
if (distance <= 100){
digitalWrite(buzzPin, LOW);
if (distance >= 100){
digitalWrite(buzzPin, HIGH);
if (customKey != 7){
delay(2000);
delay(1000);
if (customKey == 7){
