I am having problems while writing custom bootloader, so that it uploads code from EEPROM (for now internal, as I have no external memory in my hands) and writes into flash. After ~2 weeks of struggling I encountered these question and answers. After that, I realized that I made a mistake not checking the possibility of it. However, I am still confused about several things:
If Harvard Architecture limits what I want, how come optiboot can flash the memory from incoming UART data, which is not even a memory?
If UART reads and flashes memory accordingly, cant I do the same with EEPROM? Read bytes, erase flash, write bytes.
If it is not possible, given two answers in above link, then how does this work? I guess, it is the same logic as I want, using external memory and rewriting flash. Does it mean Harvard Architecture limits only internal memory exchange?
UPDATE: Here is what I have done for now:
In separate sketch, EEPROM is filled with binary code. Bootloader (edited optiboot v8):
// Set up watchdog to trigger after desired timeout
watchdogConfig(WDTPERIOD);
#if BIGBOOT
if ((eeprom_read(0x000) == 0x0C) && (eeprom_read(0x001) == 0x94))
//while (EECR & (1 << EEPE)); //wait if previous data is still being written
uint8_t i, j;
for (i = 0; i < 8; ++i) // 8 pages total
uint8_t *code;
code = buff.bptr;
address.word = (i * 128);
for (j = 0; j < 128; ++j) // 128 words at a time
if (j % 64 == 0)
LED_PORT ^= _BV(LED);
*code++ = eeprom_read(address.word + j);
#ifdef VIRTUAL_BOOT_PARTITION
virtualBootPartition(buff, address);
#endif
writebuffer(0x46, buff, address, 128);
while(1); // wait for WDT
#endif
#if (LED_START_FLASHES > 0) || LED_DATA_FLASH || LED_START_ON
/* Set LED pin as output */
LED_DDR |= _BV(LED);
#endif
while my function looks like this:
#if BIGBOOT
static uint8_t eeprom_read(uint16_t addr)
EEAR = addr; //read from that address
EECR |= (1 << EERE); //enable reading
return EEDR;
#endif
I use make atmega328 BIGBOOT=1 to generate hex file. It does not work + UART uploading also fails. If I set BIGBOOT to 0 and generate, UART uploading works fine.
P.S. virtualBootPartition is function which is called in STK_PROG_PAGE case. In order to not repeat the same piece of code, I collected that part into the function.
* How the Virtual Boot Partition works:
* At the beginning of a normal AVR program are a set of vectors that
* implement the interrupt mechanism. Each vector is usually a single
* instruction that dispatches to the appropriate ISR.
* The instruction is normally an rjmp (on AVRs with 8k or less of flash)
* or jmp instruction, and the 0th vector is executed on reset and jumps
* to the start of the user program:
* vectors: jmp startup
* jmp ISR1
* jmp ISR2
* : ;; etc
* jmp lastvector
* To implement the "Virtual Boot Partition", Optiboot detects when the
* flash page containing the vectors is being programmed, and replaces the
* startup vector with a jump to te beginning of Optiboot. Then it saves
* the applications's startup vector in another (must be unused by the
* application), and finally programs the page with the changed vectors.
* Thereafter, on reset, the vector will dispatch to the beginning of
* Optiboot. When Optiboot decides that it will run the user application,
* it fetches the saved start address from the unused vector, and jumps
* there.
* The logic is dependent on size of flash, and whether the reset vector is
* on the same flash page as the saved start address.
#if FLASHEND > 8192
- AVR with 4-byte ISR Vectors and "jmp"
- WARNING: this works only up to 128KB flash!
#if FLASHEND > (1281024)
#error "Can't use VIRTUAL_BOOT_PARTITION with more than 128k of Flash"
#endif
if (address.word == RSTVEC_ADDRESS) {
// This is the reset vector page. We need to live-patch the
// code so the bootloader runs first.
// Save jmp targets (for "Verify")
rstVect0_sav = buff.bptr[rstVect0];
rstVect1_sav = buff.bptr[rstVect1];
// Add "jump to Optiboot" at RESET vector
// WARNING: this works as long as 'main' is in first section
buff.bptr[rstVect0] = ((uint16_t)pre_main) & 0xFF;
buff.bptr[rstVect1] = ((uint16_t)pre_main) >> 8;
#if (SAVVEC_ADDRESS != RSTVEC_ADDRESS)
// the save_vector is not necessarilly on the same flash page as the reset
// vector. If it isn't, we've waiting to actually write it.
else if (address.word == SAVVEC_ADDRESS) {
// Save old values for Verify
saveVect0_sav = buff.bptr[saveVect0 - SAVVEC_ADDRESS];
saveVect1_sav = buff.bptr[saveVect1 - SAVVEC_ADDRESS];
// Move RESET jmp target to 'save' vector
buff.bptr[saveVect0 - SAVVEC_ADDRESS] = rstVect0_sav;
buff.bptr[saveVect1 - SAVVEC_ADDRESS] = rstVect1_sav;
#else
saveVect0_sav = buff.bptr[saveVect0];
saveVect1_sav = buff.bptr[saveVect1];
buff.bptr[saveVect0] = rstVect0_sav;
buff.bptr[saveVect1] = rstVect1_sav;
#endif
#else
- AVR with 2-byte ISR Vectors and rjmp
if (address.word == rstVect0) {
// the code so the bootloader runs first.
// Move RESET vector to 'save' vector
addr16_t vect;
vect.word = ((uint16_t)pre_main-1);
// Instruction is a relative jump (rjmp), so recalculate.
// an RJMP instruction is 0b1100xxxx xxxxxxxx, so we should be able to
// do math on the offsets without masking it off first.
// Note that rjmp is relative to the already incremented PC, so the
// offset is one less than you might expect.
buff.bptr[0] = vect.bytes[0]; // rjmp to start of bootloader
buff.bptr[1] = vect.bytes[1] | 0xC0; // make an "rjmp"
addr16_t vect;
vect.bytes[0] = rstVect0_sav;
vect.bytes[1] = rstVect1_sav;
vect.word = (vect.word-save_vect_num); //substract 'save' interrupt position
buff.bptr[saveVect0 - SAVVEC_ADDRESS] = vect.bytes[0];
buff.bptr[saveVect1 - SAVVEC_ADDRESS] = (vect.bytes[1] & 0x0F)| 0xC0; // make an "rjmp"
#else
buff.bptr[saveVect0] = vect.bytes[0];
buff.bptr[saveVect1] = (vect.bytes[1] & 0x0F)| 0xC0; // make an "rjmp"
// Add rjmp to bootloader at RESET vector
vect.word = ((uint16_t)pre_main-1); // (main) is always <= 0x0FFF; no masking needed.
buff.bptr[0] = vect.bytes[0]; // rjmp 0x1c00 instruction
#endif
#endif // FLASHEND
#endif // VBP
