You can try the code on your arduino UNO to better understand what is hapening in serial monitor!
I want to calculate jacobian matrix from rotation matrix!
float jakMATB[3][3] = {
{0, 0, 0},
{0, 0, 0},
{0, 0, 0}
float POKUS = 0;
float k = 0.000001;
float dt = 0.001;
float b = 90 * (PI / 180);
float vnB[3] = {0, 1, 0}, vpB[3] = {0, 1, 1};
float nB[3] = {0, 1, 0};
float nBplus[3] = {0 , 1, 0};
float nBminus[3] = {0, 1, 0};
Serial.begin(9600);
Serial.print("init ok");
cli();//stop interrupts
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = (16000000) / ((1 / dt) * 1024) - 1; // 15624 = (16*10^6) / ((1)*1024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS12 and CS10 bits for 1024 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
when I call the function in loop everithing works fine and I get 1 2 1 in serial monitor
izracunJAKOB();
for (int j = 0; j <= 2; j++) {
for (int i = 0; i <= 2; i++) {
Serial.print(jakMATB[j][i]);
Serial.print(" ");
Serial.println("");
when I call izracunJAKOB() with timer interupt Serial monitor stops working and doesent event write "init ok"
ISR(TIMER1_COMPA_vect) {
//izracunJAKOB();
void izracunJAKOB() {
nBplus[j] = nB[j] + k;
nBminus[j] = nB[j] - k;
float matricaBplus[3][3] = {
{cos(b) + nBplus[0]*nBplus[0]*(1 - cos(b)), nBplus[1]*nBplus[0]*(1 - cos(b)) - nBplus[2]*sin(b), nBplus[0]*nBplus[2]*(1 - cos(b)) + nBplus[1]*sin(b)},
{nBplus[1]*nBplus[0]*(1 - cos(b)) + nBplus[2]*sin(b), cos(b) + nBplus[1]*nBplus[1]*(1 - cos(b)), nBplus[1]*nBplus[2]*(1 - cos(b)) - nBplus[0]*sin(b)},
{nBplus[0]*nBplus[2]*(1 - cos(b)) - nBplus[1]*sin(b), nBplus[1]*nBplus[2]*(1 - cos(b)) + nBplus[0]*sin(b), nBplus[2]*nBplus[2]*(1 - cos(b)) + cos(b)}
float matricaBminus[3][3] = {
{cos(b) + nBminus[0]*nBminus[0]*(1 - cos(b)), nBminus[1]*nBminus[0]*(1 - cos(b)) - nBminus[2]*sin(b), nBminus[0]*nBminus[2]*(1 - cos(b)) + nBminus[1]*sin(b)},
{nBminus[1]*nBminus[0]*(1 - cos(b)) + nBminus[2]*sin(b), cos(b) + nBminus[1]*nBminus[1]*(1 - cos(b)), nBminus[1]*nBminus[2]*(1 - cos(b)) - nBminus[0]*sin(b)},
{nBminus[0]*nBminus[2]*(1 - cos(b)) - nBminus[1]*sin(b), nBminus[1]*nBminus[2]*(1 - cos(b)) + nBminus[0]*sin(b), nBminus[2]*nBminus[2]*(1 - cos(b)) + cos(b)}
jakMATB[i][j] = (matricaBplus[i][j] - matricaBminus[i][j]) / (2 * k);
nBplus[0] = 0;
nBplus[1] = 1;
nBplus[2] = 0;
nBminus[0] = 0;
nBminus[1] = 1;
nBminus[2] = 0;
////////////////////////////// when I comennt out
and
nBplus[0] = 0;
nBplus[1] = 1;
nBplus[2] = 0;
nBminus[0] = 0;
nBminus[1] = 1;
nBminus[2] = 0;
Serial works just fine
when I coment out only matricaBminus and matricaBplus serial works fine
Please help! It surely is a stupid solution!
