I'm trying to get an inverted pendulum project working (following the instructions here), and while my stepper motor moves the cart just fine when that's the only code in the Arduino sketch, as soon as I add the MPU 6050 sensor for detecting the angle of the pendulum, the cart moves much slower, far too slow to be useful for keeping the pendulum upright.
I imagine the timing of the motor commands is messed up by the sensor reads, but I'm not sure how to avoid the problem. Also, the author of the example posted essentially the same code as his working solution for proportional control, so there may be something else that I'm missing that messes my motor performance up.
Does anyone have any suggestions for how to get the stepper motor turning fast enough while also reading data from the MPU 6050?
My code is below. I'm using a Nema 17 stepper motor with an A4988 driver, a 12 V 10 A power supply, and this Aukru MPU-6050. To be sure that updates to the speed and Serial prints aren't the problem, I use an interval of 500 ms between updates/printing.
#include "I2Cdev.h"
#include <AccelStepper.h>
#include "MPU6050_6Axis_MotionApps20.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define INTERRUPT_PIN 2 // use pin 2 on Arduino Uno & most boards
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// === INTERRUPT DETECTION ROUTINE ===
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
// Defines pins numbers
const int stepPin = 3;
const int dirPin = 4;
AccelStepper stepper(1,stepPin,dirPin);
int motorSpeed, currentPos;
unsigned long t_start, t_elapsed;
int interval = 500; // ms between printing speed
int speedMax = 4000;
float k_proportional = 4;
float angleCurrent, speedSet;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
Serial.begin(115200);
// initialize device
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
pinMode(INTERRUPT_PIN, INPUT);
// verify connection
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
// load and configure the DMP
Serial.println(F("Initializing DMP..."));
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(220);
mpu.setYGyroOffset(76);
mpu.setZGyroOffset(-85);
mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
if (devStatus == 0) {
// turn on the DMP, now that it's ready
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
Serial.println(F("DMP ready! Waiting for first interrupt..."));
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
} else {
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
stepper.setMaxSpeed(speedMax);
stepper.setAcceleration(10000);
stepper.setSpeed(2000);
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize) {
if (mpuInterrupt && fifoCount < packetSize) {
// try to get out of the infinite loop
fifoCount = mpu.getFIFOCount();
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
} else if (mpuIntStatus & 0x02) {
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
// display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
t_elapsed = millis() - t_start;
if (t_elapsed >= interval) {
t_start += interval;
motorSpeed=setMotorSpeed();
stepper.setSpeed(motorSpeed);
Serial.print("Roll ");
Serial.print(ypr[2] * 180/M_PI);
Serial.print("Motor speed: ");
Serial.println(motorSpeed);
stepper.runSpeed();
int setMotorSpeed() {
// Proportional control
angleCurrent = ypr[2];
speedSet = constrain(-angleCurrentk_proportionalspeedMax, -speedMax, speedMax);
return speedSet;
Edit: Adding my code which limits the sensor logic to the same interval as the speed update, based on the answer by chrisl. The cart moves quite a bit faster, though still not fast enough to keep the pendulum upright.
#include "I2Cdev.h"
#include "Wire.h"
#endif
MPU6050 mpu;
unsigned long t_start, t_elapsed, t_mpu, t_start_mpu;
int interval = 50; // ms between printing speed
unsigned long count = 0;
int speedMax = 800;
float k_proportional = 3;
Wire.begin();
#endif
mpu.initialize();
dmpReady = true;
} else {
// ERROR!
stepper.setSpeed(100);
count += 1;
// Slows down cart tremendously, but code freezes without it
mpu.resetFIFO();
// Use one potentiometer to turn system on or off (A0)
int A0val = analogRead(A0);
// Use another potentiometer to tune response time (or max speed)
int A1val = analogRead(A1);
//speedMax = 2*A1val;
interval = A1val/2;
Serial.print("Roll: ");
Serial.print(", motor speed: ");
Serial.print(motorSpeed);
Serial.print(", A0: ");
Serial.print(A0val);
Serial.print(", interval: ");
Serial.print(interval);
//Serial.print(", speedMax: ");
//Serial.print(speedMax);
Serial.print(", iterations: ");
Serial.println(count);
count=0;
if (A0val > 512)
else
stepper.setSpeed(0);
stepper.runSpeed();
return speedSet;
