I was following FREE Functions to draw graphs on OLED displays on YouTube but mine OLED display doesn't support Adafruit_SSD1306 library,but it works on Adafruit_SH1106.h driver.
The code that is shared with YouTube video
This program provides functions to draw:
  1. horizontal bar graph
  2. vertical bar graph
  3. dial
  4. cartesian graph
It requires an microcrontrioller Arduino, teensy and a 0.96 dispaly (1306 driver chip)
display. sources https://www.amazon.com/Diymall-Yellow-Arduino-display.-Raspberry/dp/B00O2LLT30/ref=pd_lpo_vtph_147_bs_t_1?_encoding=UTF8&psc=1&refRID=BQAPE07SVJQNDKEVMTQZ https://www.amazon.com/dp/B06XRCQZRX/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B06XRCQZRX&pd_rd_wg=aGuhK&pd_rd_r=1WJPXAG68XFSADGDPNZR&pd_rd_w=DAAsB
Adafruit libraries https://github.com/adafruit/Adafruit-GFX-Library/archive/master.zip https://github.com/adafruit/Adafruit_SSD1306
Revisions rev date author description 1 12-5-2017 kasprzak initial creation
Pin settings
Arduino device 5V Vin GND GND A0 read an input voltage from a pot across Vcc and Gnd (just for demo purposes) A1 A2 A3 A4 SDA on the display. or use dedicated pin on board if provided A5 SCL on the display. use dedicated pin on board if provided 1 2 3 4 5 6 7 8 9 10 11 12 13
#include <Adafruit_GFX.h> #include <Adafruit_SSD1306.h>
#define READ_PIN A0 #define OLED_RESET A4 #define LOGO16_GLCD_HEIGHT 16 #define LOGO16_GLCD_WIDTH 16
// create what ever variables you need double volts; double bvolts; double x, y;
// these are a required variables for the graphing functions bool Redraw1 = true; bool Redraw2 = true; bool Redraw3 = true; bool Redraw4 = true; double ox , oy ;
// create the display object Adafruit_SSD1306 display(OLED_RESET);
Serial.begin(9600);
// initialize the display // note you may have to change the address // the most common are 0X3C and 0X3D
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // if you distribute your code, the adafruit license requires you show their splash screen // otherwise clear the video buffer memory then display display.display(); //delay(2000); display.clearDisplay(); display.display();
// establish whatever pin reads you need pinMode(A0, INPUT);
unsigned long OldTime; unsigned long counter;
void loop(void) {
// read some values and convert to volts bvolts = analogRead(A0); volts = (bvolts / 204.6 ) ;
// draw any of the following, sorry for the crazy long arguement lists // note 0.96 isn't very big, so you can't show many graphs at the same time // also colors are hard coded // the display i use draws text at the top in yellow--we'll use that for drawing the title
// call one of these functions DrawBarChartV(display, bvolts, 25, 60, 40, 40, 0, 1024 , 256, 0, "A0 (bits)", Redraw1); // DrawBarChartH(display, volts, 10, 45, 100, 20, 0, 5, 1, 0, "A0 (volts)", Redraw2); // DrawDial(display, volts, 65, 50, 25, 0, 5 , 1, 0, 200, "A0 (volts)", Redraw3);
// for multiple graphs uncomment the next 2 lines // DrawBarChartV(display, bvolts, 5, 60, 10, 40, 0, 1024 , 256, 0, "A0 (bits/volts)", Redraw1); // DrawDial(display, volts, 90, 50, 25, 0, 5 , 1, 0, 200, "A0 (bits/volts)", Redraw3);
// or show a cartesian style graph to plot values over time (or whatever)
DrawCGraph(display, x++, bvolts, 30, 50, 75, 30, 0, 100, 25, 0, 1024, 512, 0, &quot;Bits vs Seconds&quot;, Redraw4);
if (x &gt; 100) {
while (1) {}
delay(1000);
/* This method will draw a vertical bar graph for single input it has a rather large arguement list and is as follows
&d to pass the display object, mainly used if multiple displays are connected to the MCU curval = date to graph (must be between loval and hival) x = position of bar graph (lower left of bar) y = position of bar (lower left of bar w = width of bar graph h = height of bar graph (does not need to be the same as the max scale) loval = lower value of the scale (can be negative) hival = upper value of the scale inc = scale division between loval and hival dig = format control to set number of digits to display. (not includeing the decimal) label = bottom lable text for the graph redraw = flag to redraw display. only on first pass (to reduce flickering)
void DrawBarChartV(Adafruit_SSD1306 &d, double curval, double x , double y , double w, double h , double loval , double hival , double inc , double dig, String label, bool &Redraw) { double stepval, my, level, i, data;
if (Redraw) { Redraw = false; d.fillRect(0, 0, 127 , 14, SSD1306_WHITE); d.setTextColor(SSD1306_BLACK, SSD1306_WHITE); d.setTextSize(1); d.setCursor(2, 4); d.println(label); // step val basically scales the hival and low val to the height // deducting a small value to eliminate round off errors // this val may need to be adjusted stepval = ( inc) * (double (h) / (double (hival - loval))) - .001; for (i = 0; i <= h; i += stepval) { my = y - h + i; d.drawFastHLine(x + w + 1, my, 5, SSD1306_WHITE); // draw lables d.setTextSize(1); d.setTextColor(SSD1306_WHITE, SSD1306_BLACK); d.setCursor(x + w + 12, my - 3 ); data = hival - ( i * (inc / stepval)); d.print(data, dig); } } // compute level of bar graph that is scaled to the height and the hi and low vals // this is needed to accompdate for +/- range level = (h * (((curval - loval) / (hival - loval)))); // draw the bar graph // write a upper and lower bar to minimize flicker cause by blanking out bar and redraw on update d.drawRect(x, y - h, w, h, SSD1306_WHITE); d.fillRect(x, y - h, w, h - level, SSD1306_BLACK); d.drawRect(x, y - h, w, h, SSD1306_WHITE); d.fillRect(x, y - level, w, level, SSD1306_WHITE); // up until now print sends data to a video buffer NOT the screen // this call sends the data to the screen d.display();
/* This method will draw a horizontal bar graph for single input it has a rather large arguement list and is as follows
&display to pass the display object, mainly used if multiple displays are connected to the MCU x = position of bar graph (upper left of bar) curval = date to graph (must be between loval and hival) y = position of bar (upper left of bar (add some vale to leave room for label) w = width of bar graph (does not need to be the same as the max scale) h = height of bar graph loval = lower value of the scale (can be negative) hival = upper value of the scale inc = scale division between loval and hival dig = format control to set number of digits to display. (not includeing the decimal) label = bottom lable text for the graph redraw = flag to redraw display. only on first pass (to reduce flickering) */
void DrawBarChartH(Adafruit_SSD1306 &d, double curval, double x , double y , double w, double h , double loval , double hival , double inc , double dig, String label, bool &Redraw) { double stepval, mx, level, i, data;
if (Redraw) { Redraw = false; d.fillRect(0, 0, 127 , 16, SSD1306_WHITE); d.setTextColor(SSD1306_BLACK, SSD1306_WHITE); d.setTextSize(1); d.setCursor(2, 4); d.println(label); // step val basically scales the hival and low val to the width stepval = inc * (double (w) / (double (hival - loval))) - .00001; // draw the text for (i = 0; i <= w; i += stepval) { d.drawFastVLine(i + x , y , 5, SSD1306_WHITE); // draw lables d.setTextSize(1); d.setTextColor(SSD1306_WHITE, SSD1306_BLACK); d.setCursor(i + x , y + 10); // addling a small value to eliminate round off errors // this val may need to be adjusted data = ( i * (inc / stepval)) + loval + 0.00001; d.print(data, dig); } } // compute level of bar graph that is scaled to the width and the hi and low vals // this is needed to accompdate for +/- range capability // draw the bar graph // write a upper and lower bar to minimize flicker cause by blanking out bar and redraw on update level = (w * (((curval - loval) / (hival - loval)))); d.fillRect(x + level, y - h, w - level, h, SSD1306_BLACK); d.drawRect(x, y - h, w, h, SSD1306_WHITE); d.fillRect(x, y - h, level, h, SSD1306_WHITE); // up until now print sends data to a video buffer NOT the screen // this call sends the data to the screen d.display();
/* This method will draw a dial-type graph for single input it has a rather large arguement list and is as follows
&display to pass the display object, mainly used if multiple displays are connected to the MCU curval = date to graph (must be between loval and hival) cx = center position of dial cy = center position of dial r = radius of the dial loval = lower value of the scale (can be negative) hival = upper value of the scale inc = scale division between loval and hival sa = sweep angle for the dials scale dig = format control to set number of digits to display. (not includeing the decimal) label = bottom lable text for the graph redraw = flag to redraw display. only on first pass (to reduce flickering) */
void DrawDial(Adafruit_SSD1306 &d, double curval, int cx, int cy, int r, double loval , double hival , double inc, double dig, double sa, String label, bool &Redraw) {
double ix, iy, ox, oy, tx, ty, lx, rx, ly, ry, i, Offset, stepval, data, angle; double degtorad = .0174532778; static double px = cx, py = cy, pix = cx, piy = cy, plx = cx, ply = cy, prx = cx, pry = cy;
if (Redraw) { Redraw = false; // draw the dial only one time--this will minimize flicker d.fillRect(0, 0, 127 , 16, SSD1306_WHITE); d.setTextColor(SSD1306_BLACK, SSD1306_WHITE); d.setTextSize(1); d.setCursor(2, 4); d.println(label); // center the scale about the vertical axis--and use this to offset the needle, and scale text Offset = (270 + sa / 2) * degtorad; // find hte scale step value based on the hival low val and the scale sweep angle // deducting a small value to eliminate round off errors // this val may need to be adjusted stepval = ( inc) * (double (sa) / (double (hival - loval))) + .00; // draw the scale and numbers // note draw this each time to repaint where the needle was for (i = 0; i <= sa; i += stepval) { angle = ( i * degtorad); angle = Offset - angle ; ox = (r - 2) * cos(angle) + cx; oy = (r - 2) * sin(angle) + cy; ix = (r - 10) * cos(angle) + cx; iy = (r - 10) * sin(angle) + cy; tx = (r + 10) * cos(angle) + cx + 8; ty = (r + 10) * sin(angle) + cy; d.drawLine(ox, oy, ix, iy, SSD1306_WHITE); d.setTextSize(1); d.setTextColor(SSD1306_WHITE, SSD1306_BLACK); d.setCursor(tx - 10, ty ); data = hival - ( i * (inc / stepval)) ; d.println(data, dig); } for (i = 0; i <= sa; i ++) { angle = ( i * degtorad); angle = Offset - angle ; ox = (r - 2) * cos(angle) + cx; oy = (r - 2) * sin(angle) + cy; d.drawPixel(ox, oy, SSD1306_WHITE); } } // compute and draw the needle angle = (sa * (1 - (((curval - loval) / (hival - loval))))); angle = angle * degtorad; angle = Offset - angle ; ix = (r - 10) * cos(angle) + cx; iy = (r - 10) * sin(angle) + cy; // draw a triangle for the needle (compute and store 3 vertiticies) lx = 2 * cos(angle - 90 * degtorad) + cx; ly = 2 * sin(angle - 90 * degtorad) + cy; rx = 2 * cos(angle + 90 * degtorad) + cx; ry = 2 * sin(angle + 90 * degtorad) + cy;
// blank out the old needle d.fillTriangle (pix, piy, plx, ply, prx, pry, SSD1306_BLACK);
// then draw the new needle d.fillTriangle (ix, iy, lx, ly, rx, ry, SSD1306_WHITE);
// draw a cute little dial center d.fillCircle(cx, cy, 3, SSD1306_WHITE);
//save all current to old so the previous dial can be hidden pix = ix; piy = iy; plx = lx; ply = ly; prx = rx; pry = ry; // up until now print sends data to a video buffer NOT the screen // this call sends the data to the screen d.display();
function to draw a cartesian coordinate system and plot whatever data you want just pass x and y and the graph will be drawn huge arguement list
&display to pass the display object, mainly used if multiple displays are connected to the MCU x = x data point y = y datapont gx = x graph location (lower left) gy = y graph location (lower left) w = width of graph h = height of graph xlo = lower bound of x axis xhi = upper bound of x asis xinc = division of x axis (distance not count) ylo = lower bound of y axis yhi = upper bound of y asis yinc = division of y axis (distance not count) title = title of graph &redraw = flag to redraw graph on fist call only
void DrawCGraph(Adafruit_SSD1306 &d, double x, double y, double gx, double gy, double w, double h, double xlo, double xhi, double xinc, double ylo, double yhi, double yinc, double dig, String title, boolean &Redraw) {
double i; double temp; int rot, newrot;
if (Redraw == true) { Redraw = false; d.fillRect(0, 0, 127 , 16, SSD1306_WHITE); d.setTextColor(SSD1306_BLACK, SSD1306_WHITE); d.setTextSize(1); d.setCursor(2, 4); d.println(title); ox = (x - xlo) * ( w) / (xhi - xlo) + gx; oy = (y - ylo) * (gy - h - gy) / (yhi - ylo) + gy; // draw y scale d.setTextSize(1); d.setTextColor(SSD1306_WHITE, SSD1306_BLACK); for ( i = ylo; i <= yhi; i += yinc) { // compute the transform // note my transform funcition is the same as the map function, except the map uses long and we need doubles temp = (i - ylo) * (gy - h - gy) / (yhi - ylo) + gy; if (i == 0) { d.drawFastHLine(gx - 3, temp, w + 3, SSD1306_WHITE); } else { d.drawFastHLine(gx - 3, temp, 3, SSD1306_WHITE); } d.setCursor(gx - 27, temp - 3); d.println(i, dig); } // draw x scale for (i = xlo; i <= xhi; i += xinc) { // compute the transform d.setTextSize(1); d.setTextColor(SSD1306_WHITE, SSD1306_BLACK); temp = (i - xlo) * ( w) / (xhi - xlo) + gx; if (i == 0) { d.drawFastVLine(temp, gy - h, h + 3, SSD1306_WHITE); } else { d.drawFastVLine(temp, gy, 3, SSD1306_WHITE); } d.setCursor(temp, gy + 6); d.println(i, dig); } }
// graph drawn now plot the data // the entire plotting code are these few lines...
x = (x - xlo) * ( w) / (xhi - xlo) + gx; y = (y - ylo) * (gy - h - gy) / (yhi - ylo) + gy; d.drawLine(ox, oy, x, y, SSD1306_WHITE); d.drawLine(ox, oy - 1, x, y - 1, SSD1306_WHITE); ox = x; oy = y;
For my purpose of running this project in my OLED I replaced all SSD1306 keyword with SH1106. Except this project every other projects works on this OLED by replacing SSD1306 keyword with SH1106.
Getting this error in Ardunio IDE 'SH1106_WHITE' was not declared in this scope
Arduino: 1.8.13 Hourly Build 2020/04/21 12:25 (Linux), Board: "Arduino Uno"
/tmp/arduino_modified_sketch_953644/sketch_oct07a.ino: In function 'void DrawBarChartV(Adafruit_SH1106&, double, double, double, double, double, double, double, double, double, String, bool&)': sketch_oct07a:162:33: error: 'SH1106_WHITE' was not declared in this scope d.fillRect(0, 0, 127 , 14, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:162:33: note: suggested alternative: 'SH1106_LCDWIDTH' d.fillRect(0, 0, 127 , 14, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH sketch_oct07a:163:20: error: 'SH1106_BLACK' was not declared in this scope d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:163:20: note: suggested alternative: 'SH1106_128_64' d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:187:30: error: 'SH1106_WHITE' was not declared in this scope d.drawRect(x, y - h, w, h, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:187:30: note: suggested alternative: 'SH1106_LCDWIDTH' d.drawRect(x, y - h, w, h, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH sketch_oct07a:188:39: error: 'SH1106_BLACK' was not declared in this scope d.fillRect(x, y - h, w, h - level, SH1106_BLACK); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:188:39: note: suggested alternative: 'SH1106_128_64' d.fillRect(x, y - h, w, h - level, SH1106_BLACK); ^~~~~~~~~~~~ SH1106_128_64 /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino: In function 'void DrawBarChartH(Adafruit_SH1106&, double, double, double, double, double, double, double, double, double, String, bool&)': sketch_oct07a:221:33: error: 'SH1106_WHITE' was not declared in this scope d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:221:33: note: suggested alternative: 'SH1106_LCDWIDTH' d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH sketch_oct07a:222:20: error: 'SH1106_BLACK' was not declared in this scope d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:222:20: note: suggested alternative: 'SH1106_128_64' d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:246:47: error: 'SH1106_BLACK' was not declared in this scope d.fillRect(x + level, y - h, w - level, h, SH1106_BLACK); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:246:47: note: suggested alternative: 'SH1106_128_64' d.fillRect(x + level, y - h, w - level, h, SH1106_BLACK); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:247:31: error: 'SH1106_WHITE' was not declared in this scope d.drawRect(x, y - h, w, h, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:247:31: note: suggested alternative: 'SH1106_LCDWIDTH' d.drawRect(x, y - h, w, h, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino: In function 'void DrawDial(Adafruit_SH1106&, double, int, int, int, double, double, double, double, double, String, bool&)': sketch_oct07a:283:33: error: 'SH1106_WHITE' was not declared in this scope d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:283:33: note: suggested alternative: 'SH1106_LCDWIDTH' d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH sketch_oct07a:284:20: error: 'SH1106_BLACK' was not declared in this scope d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:284:20: note: suggested alternative: 'SH1106_128_64' d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:333:49: error: 'SH1106_BLACK' was not declared in this scope d.fillTriangle (pix, piy, plx, ply, prx, pry, SH1106_BLACK); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:333:49: note: suggested alternative: 'SH1106_128_64' d.fillTriangle (pix, piy, plx, ply, prx, pry, SH1106_BLACK); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:336:43: error: 'SH1106_WHITE' was not declared in this scope d.fillTriangle (ix, iy, lx, ly, rx, ry, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:336:43: note: suggested alternative: 'SH1106_LCDWIDTH' d.fillTriangle (ix, iy, lx, ly, rx, ry, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino: In function 'void DrawCGraph(Adafruit_SH1106&, double, double, double, double, double, double, double, double, double, double, double, double, double, String, boolean&)': sketch_oct07a:388:33: error: 'SH1106_WHITE' was not declared in this scope d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:388:33: note: suggested alternative: 'SH1106_LCDWIDTH' d.fillRect(0, 0, 127 , 16, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH sketch_oct07a:389:20: error: 'SH1106_BLACK' was not declared in this scope d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:389:20: note: suggested alternative: 'SH1106_128_64' d.setTextColor(SH1106_BLACK, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_128_64 sketch_oct07a:433:28: error: 'SH1106_WHITE' was not declared in this scope d.drawLine(ox, oy, x, y, SH1106_WHITE); ^~~~~~~~~~~~ /tmp/arduino_modified_sketch_953644/sketch_oct07a.ino:433:28: note: suggested alternative: 'SH1106_LCDWIDTH' d.drawLine(ox, oy, x, y, SH1106_WHITE); ^~~~~~~~~~~~ SH1106_LCDWIDTH exit status 1 'SH1106_WHITE' was not declared in this scope
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
I am new to this field. Any help will be appreciated.
VA splash
  • 123
In the Adafruit_SH1106.h header file, SH1106_WHITE and SH1106_BLACK are defined simply as WHITE and BLACK respectively. So instead of writing SH1106_WHITE try replacing it WHITE and SH1106_BLACK as BLACK respectively.
Eg:- fillRect(0, 0, 127 , 14, WHITE);
Manav
  • 426
