I want to pass a lambda function as an argument to a method. Example:
T reduce(const T initial, const std::function<T(T, T)> acc) {
    T value = initial;
    for (size_t i = 0; i < S; ++i) {
        value = acc(value, this->values[i]);
return value;
int sum = this->reduce(42, [](int acc, int value) { return acc + value; });
If I try to compile this code for Arduino, I get an obvious error:
error: 'function' in namespace 'std' does not name a template type
How can I use a lambda function in Arduino?
Arseni Mourzenko
  • 246
std::function is not supported by the Arduino environment. (Edit: as mentioned by KIIV in a comment, it's supported on ARM targets, but not on AVR.) You can, however, pass a non-capturing lambda to a function that expects a plain function pointer. For example, given
T reduce(const T initial, T (*acc)(T, T)) {
    T value = initial;
    return value;
You can call it as
int sum = test.reduce(42, [](int acc, int value){ return acc + value; });
If you want your lambda to capture something, it would seem you are out of luck...
Edgar Bonet
  • 45,094
  • 81
