I've been trying to connect an MPU6050 to my MKR WIFI 1010 following these general instructions and using the I2CDev library, but I keep running into problems.
For a while the Arduino just didn't show up as connected in the IDE when all the pins were connected, which I think I've gathered was due to a lack of pull-up resistors for the SCL/SDA pins. Adding 10 kOhm pull-up resistors helped a little (in making the Arduino visible) but it would hang when trying to upload the example sketch. 2.2 kOhm resistors seemed to do the trick, where now the example sketches (MPU6050_DMP6 or MPU6050_raw) can be uploaded. They still fail to read any actual values, however. The raw sketch gives 0 for everything, and the DMP6 sketch prints
Initializing I2C devices...
Testing device connections...
MPU6050 connection failed
Send any character to begin DMP programming and demo: Initializing DMP... DMP Initialization failed (code 1)
Does anyone know why the sensor still fails to give any measurements? I connect VCC and GND from the sensor to VCC (3.3V) and GND from my Arduino. SCL and SDA from the sensor are connected to VCC via 2.2 kOhm resistors and to the SCL and SDA pins of the Arduino (12 and 11). And INT from the sensor is connected to digital pin 2. (I tried this on a couple other pins like 0 and 1 since it seems from the tech specs that 2 is not an External Interrupt pin, but that didn't change anything.)
The sensor and examples worked without any extra effort on my Arduino Uno, but unfortunately I fried that with a 12V power supply by accident. I'll probably just get another Uno, but I'm curious why this didn't work, if I'm missing something about I2C or the MKR WIFI.
I'll also note that I had to add
define #BUFFER_LENGTH 64
to wire.h in order to get sketches including I2Cdev to compile (following these instructions).
Frecka
  • 33
The sensor was indeed broken, and I had no problems after ordering a new one.
Frecka
  • 33
