I have this project where I need a modbus tcp server that will host a series of sensor data for other modbus client devices to read. I use this Library by Andresoarmento
This is the code i am using from the library example:
#include <EtherCard.h>
#include <Modbus.h>
#include <ModbusIP_ENC28J60.h>
//Modbus Registers Offsets (0-9999) const int SENSOR_IREG = 100; //Used Pins //const int sensorPin = A0;
//ModbusIP object ModbusIP mb;
long ts;
void setup() { // The media access control (ethernet hardware) address for the shield byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // The IP address for the shield byte ip[] = { 192, 168, 1, 120 }; //Config Modbus IP mb.config(mac, ip);
// Add SENSOR_IREG register - Use addIreg() for analog Inputs
int i = 2200;
mb.addIreg(SENSOR_IREG,i);
ts = millis();
void loop() { //Call once inside loop() - all magic here mb.task();
//Read each two seconds if (millis() > ts + 2000) { ts = millis(); //Setting raw value (0-1024) int i = 0; i++; mb.Ireg(SENSOR_IREG, i); }
The enj28j60 module is working as i tested it. So, I used a modbus scanner(CAS SCANNER) which was unable to detect it. Can anyone tell me how to get this all working and test it?
Thank you in advance.
Deadpool
