I'm trying to do a small test where I am using the ISR on the Arduino Pro Micro it up from sleep mode. I'm using a Force Sense Resistor (FSR, a resistor that changes it's resistance depending on how hard you press it) with a voltage divider circuit with the output of the voltage divider connected to an analog pin and the digital interrupt pin. I'm not able to get the interrupt to trigger no matter what condition I have. I don't believe the Vout on the voltage divider is too low since the ADC registers values between 0 to 1000 (0V to about 4.8V) when the FSR is pressed. Is there anything wrong with my code that is preventing my test from working properly?
uint8_t LED = 9;
uint8_t wakeup = 2;
uint8_t enable = 0;
void Wakeup(void);
pinMode(LED, OUTPUT);
pinMode(wakeup, INPUT);
attachInterrupt(digitalPinToInterrupt(1), Wakeup, RISING);
Serial.begin(115200);
// put your main code here, to run repeatedly:
//Serial.println(analogRead(A2));
if (enable == HIGH)
digitalWrite(LED, HIGH);
else if (enable == LOW)
digitalWrite(LED, LOW);
if (analogRead(A2) < 700)
enable = 0;
void Wakeup(void) {
enable = 1;
Serial.println("Interrupt");
