First off, I should note that I'm not sure what tags best apply here, and I can't seem to find any that relate to schedulers, etc. Please inform me if they are not the right ones.
I have a simple, portable task scheduler (it only relies on millis(), and runs on different Arduino-supported systems) that is called via a function in loop() and that picks and then runs a function pointer (the "task") from a list of tasks with status, sleep, and priority information.
I would like to have a way to determine and to tell the user how much CPU time is being spent on running tasks vs. being idle.
The problem is that there can be other functions being called from loop(), not just my scheduler. It would thus be a bad idea to track total time vs. time spent in a task. If I did, the CPU use would always read low, since the actual task time cannot use all of the CPU time since the other tasks in loop() would be quietly using some of it.
However, if I specifically track time in the scheduler vs. time spent in task, I run into a new issue. I would use more memory (a few more bytes, but I'm using a lot already...) and more CPU*, since I'd have to keep track of the total so far and also the current runtime for that iteration of the scheduler. That's on top of the similar construct determining the runtime of the task. Mainly, though, the issue is that the loop() function and scheduler run fast enough that the millis() timer can tick slower than the changeover between my scheduler and the loop() function. This causes the timing to also be off, since it would be counted if it ticks in the scheduler even if it was mainly loop()'s fault.
Is there a general methodology for computing the CPU time? It would be difficult to time-slice the scheduler, and that would run slower anyway. I could count the proportion of scheduler calls that run/don't run tasks, but that won't work because tasks take longer than the no-op that happens if a task doesn't run, and it makes no accounting for task length.
*On an AVR system, the 8-bit CPU uses a surprising aggregate time on all those 32-bit operations, between the sleep time calculations (on sleeping tasks only, to be fair) and the elapsed time calculations that fed into my prior CPU use attempt. It wasn't the only cause, but I saw quite a bit of timing slip on one attempt of coding the scheduler because of a similar issue.
