Following is the program for scanning a keyboard for MIDI transfer. At present the code works fine, but it could be faster. I need to know how to use direct port manipulation inside the for loop.
boolean keypressed[6][6]; //for storing key states
int midinote[6][6] ={ 60 ,61 ,62 ,63 ,64 ,65
                 ,66 ,67 ,68 ,69 ,70 ,71
                 ,72 ,73 ,74 ,75 ,76 ,77
                 ,78 ,79 ,80 ,81 ,82 ,83
                 ,84 ,85 ,86 ,87 ,88 ,89
                 ,90 ,91 ,92 ,93 ,94 ,95  }; //code for various midi notes C3 to C6
Serial.begin(38400); for(int i=0; i<6; i++){ pinMode(i+2,OUTPUT); digitalWrite(i+8,HIGH); } for(int i=0; i<6; i++){ pinMode(i+8,INPUT); digitalWrite(i+8,HIGH); } for(int i=0; i<6; i++){ for(int j=0; j<6; j++){ keypressed[i][j] = false; } } } void loop() {
for(int i=0; i<6; i++){ digitalWrite(i+2, LOW); for(int j =0; j<6; j++){ if ((digitalRead(j+8) == LOW) && !keypressed[i][j]){ Serial.write(0x91); Serial.write(midinote[i][j]); Serial.write(127); keypressed[i][j] = true; } if ((digitalRead(j+8) == HIGH) && keypressed[i][j]){ Serial.write(0x91); Serial.write(midinote[i][j]); Serial.write(0); keypressed[i][j] =false; } } digitalWrite(i+2, HIGH); }
User
  • 139
It is better to use interrupts instead of pooling pins. but this is related to your arduino controller. what is you arduino core controller? if you can select I prefer "Nano 33 IoT " which has 9 pins (2, 3, 9, 10, 11, 13, 15, A5, A7) available for interrupt. this page may be usable: https://playground.arduino.cc/Main/PinChangeInterrupt/
