I am recieving SD card failuer and I did everything I could.
I use the correct SPI pins;
CS > 10
MOSI > 11
MISO > 12
SCK > 13
VCC > 5v
GND > GND
I did format my SD card to FAT32
I did write;
pinMode(csPin, OUTPUT);
digitalWrite(csPin, HIGH);
and I did add a blank file to sd card.
pls make harambe live ;-;
here is my code;
#include <pcmConfig.h>
#include <pcmRF.h>
#include <TMRpcm.h>
#include <SD.h>
#define sd_pin 10
TMRpcm tmr;
int speaker_pin = 3;
int trig_pin = 8;
int echo_pin = 9;
int buzzer_pin = 6;
long cm;
long lecture_echo;
void setup()
Serial.begin(9600);
Serial.println("active");
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
if(!SD.begin(sd_pin)){
Serial.println("harambe is dead");
return;
else{
Serial.println("harambe is alive");
tmr.speakerPin = speaker_pin;
pinMode(echo_pin, INPUT);
digitalWrite(trig_pin, LOW);
pinMode(trig_pin, OUTPUT);
pinMode(buzzer_pin, OUTPUT);
void loop()
digitalWrite(trig_pin, HIGH);
delay(100);
lecture_echo = pulseIn(echo_pin, HIGH);
cm = lecture_echo / 58;
Serial.println(cm);
delay(500);
if(cm < 4)
else
tmr.setVolume(5);
tmr.play("test");
