Example sketch does not compile, error message 'static void WiFiClass::init()' is private within this context IDE 1.8.13 Board Uno WiFi Dev Ed. I have been using this board for several years uploading to Thingspeak using UnoWiFiDevEd.h using Ciao. Now I am trying to use the UnoWiFiDevEdSerial1.h library but I can't even compile the example code below. Any suggestions?
/* WiFiLink example: WebClient https://github.com/jandrassy/arduino-library-wifilink */
#include <UnoWiFiDevEdSerial1.h> #include <WiFiLink.h>
char server[] = "arduino.cc"; boolean sendRequest = true;
WiFiClient client;
void setup() { Serial.begin(115200);
Serial1.begin(115200); Serial1.resetESP(); delay(3000); //wait while WiFiLink firmware connects to WiFi with Web Panel settings
WiFi.init(&Serial1); while (WiFi.status() != WL_CONNECTED) { delay(10); } Serial.println("You're connected to the network"); printWifiStatus(); Serial.println(); }
void loop() { if (sendRequest) {
/Users/mack/Documents/Arduino/UnoWiFiLink_DevEd/UnoWiFiLink_DevEd.ino: In function 'void setup()': UnoWiFiLink_DevEd:21:8: error: 'static void WiFiClass::init()' is private within this context WiFi.init(&Serial1); ^~~~ In file included from /Users/mack/Documents/Arduino/UnoWiFiLink_DevEd/UnoWiFiLink_DevEd.ino:7:0: /Users/mack/Documents/Arduino/libraries/WiFi_Link/src/WiFiLink.h:44:17: note: declared private here static void init(); ^~~~ UnoWiFiLink_DevEd:21:21: error: no matching function for call to 'WiFiClass::init(UnoWiFiDevEdSerial1*)' WiFi.init(&Serial1); ^ In file included from /Users/mack/Documents/Arduino/UnoWiFiLink_DevEd/UnoWiFiLink_DevEd.ino:7:0: /Users/mack/Documents/Arduino/libraries/WiFi_Link/src/WiFiLink.h:44:17: note: candidate: static void WiFiClass::init() static void init(); ^~~~ /Users/mack/Documents/Arduino/libraries/WiFi_Link/src/WiFiLink.h:44:17: note: candidate expects 0 arguments, 1 provided Using library Uno_WiFi_Developer_Edition_Serial1 at version 1.0.4 in folder: /Users/mack/Documents/Arduino/libraries/Uno_WiFi_Developer_Edition_Serial1 Using library WiFi_Link at version 1.0.1 in folder: /Users/mack/Documents/Arduino/libraries/WiFi_Link Using library Wire at version 1.0 in folder: /private/var/folders/5v/dc3kh_4136g2j560dgjg3vww0000gn/T/AppTranslocation/E151A1AA-2F37-45B4-9B3C-A69070247D9C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire exit status 1 'static void WiFiClass::init()' is private within this context
Juraj
  • 18,264
  • 49
Mack
