EDIT: Alright I'm stupid, I had the 2012 library installed somehow, maybe when I downloaded it indirectly from another old tutorial site. Thanks a ton to Peter Freerick for pointing that out! It finally compiled now
So I'm currently doing a little project where I have an ATTiny85 controlling some (neopixel) RGB addressable LEDs, which is controlled over i2c from an Arduino UNO Master. The goal is to make an Attiny85 into an i2c slave that receives a simple command (such as a single digit int) and decide which premade LED display program to use.
I'm using ATTinyCore, TinyWireS, and Adafruit's tinyNeopixel library for the tiny, and programming it using an Arduino UNO as ISP.
My issue is this: The led code requires a delay to change the speed of the light show. But I see in the TinyWireS example here that I should be using tws_delay instead of the normal delay.
Various googling attempts have left me nowhere to learn how to use tws_delay, what it is, or how to even declare it. I get a declaration error when I try to use the delay with the TinyWireS library included.
I would like to find a resource for learning how to declare and use this delay. Thank you for reading this far
EDIT: I have now added my code and error below, you can find the tws_delay in void loop near the bottom
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#if (F_CPU>7370000) //neopixel library required 7.37MHz minimum clock speed; this line is used to skip this sketch in internal testing. It is not needed in your sketches. #include <tinyNeoPixel.h> #include <TinyWireS.h> // Which pin on the Arduino is connected to the NeoPixels? #define PIN 3
// How many NeoPixels are attached to the Arduino? #define NUMPIXELS 8
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals. // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest // example for more information on possible values. tinyNeoPixel pixels = tinyNeoPixel(NUMPIXELS, PIN, NEO_RGB + NEO_KHZ800);
int delayval = 500; // delay for half a second
pixels.begin(); // This initializes the NeoPixel library. }
// For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(0,150,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
tws_delay(delayval); // Delay for a period of time (in milliseconds).
} } #else //neopixel library required 7.37MHz minimum clock speed; these and following lines are used to skip this sketch in internal testing. It is not needed in your sketches. #warning "Neopixel control requires F_CPU > 7.37MHz" void setup() {} void loop() {} #endif
And the error:
C:\Users\Dean\AppData\Local\Temp\arduino_modified_sketch_145294\simple.ino: In function 'void loop()':
simple:36:5: error: 'tws_delay' was not declared in this scope
C:\Users\Dean\AppData\Local\Temp\arduino_modified_sketch_145294\simple.ino:36:5: note: suggested alternative: 'delay'
 delay
Multiple libraries were found for "tinyNeoPixel.h" Used: C:\Users\Dean\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.3.2\libraries\tinyNeoPixel Multiple libraries were found for "TinyWireS.h" Used: C:\Users\Dean\Documents\Arduino\libraries\TinyWireS exit status 1 'tws_delay' was not declared in this scope
tws_delay() is a function provided by the TinyWireS library here. As you can see from the declaration - void tws_delay(unsigned long); - it accepts a parameter of unsigned long, just like delay() does.
In fact, the comment on the line above that declaration says...
// Implement a delay loop that checks for the stop bit (basically direct copy of the stock arduino implementation from wiring.c)
... so, it's safe to say that wherever you would have used delay(), you can use tws_delay().
So there should be no need to declare or define it. But to simply use it. If using tws_delay() in code that includes TinyWireS.h doesn't work, I would be checking that you have a version of the library that declares/defines it. Which you should, given the example you linked, as that repo has had the function since 2012!
Peter Feerick
  • 310
Answer: Make sure you install the right library :P
