As I been learning Arduino (micro controllers, c++, etc) I have learned that memory is very limited. I already understand how memory works when it comes to variables. But I do not understand how memory works when it comes to functions. Since I am a backed developer I try to stay away from interrupts and instead use callback functions. Another reason why I prefer to use callback functions is because I love the visual studio IDE. I create my core functionality of whatever project I am building on a c++ project targeted for Windows. Once my algorithms/logic works the way I want it I reference those libraries on Arduino.
Anyways I am using lambdas to pass functions to my helper libraries. That way I do not use the delay function to wait for a response and I am always listening for events. Basically my question is if it is correct to have code like this (function SendEvent):
/* MyRadioLibrary.h */
// I am not including all the code of `MyRadioLibrary` because that makes it hard to
// understand what I am asking. Instead I will try to use a lot of pseudo-code. Let me
// know if you want me to post the code as an edit.
class MyRadioLibrary {
public:
static void SendEvent(int typeOfEvent, void(*onEventCompleted)(bool x))
    // I have an array of pointers to functions
    void(*onEventCompletedBuffer[10])(bool x);
    // I enqueue that event with a queue helper class
    // Send event ....
    // DO NOW WAIT FOR RESPONSE SINCE CALL BACK IS ALREADY SAVED
static void loop() {
     // listen for radio messages
     if(radio.available()){
            // get response
            // dequeue pointer to call back
            // execute call back
And my arduino sketch contains this code:
#include <MyRadioLibrary.h>
void setup() { // setup pins etc.. }
if (isButton1Pressed())
    MyRadioLibrary::SendEvent(1, [](bool didEventCompletedSuccessfully) {
        if (didEventCompletedSuccessfully)
            // turn on green LED
        else {
            // turn on red led
else if (isButton2Pressed())
    MyRadioLibrary::SendEvent(2, [](bool didEventCompletedSuccessfully) {
         // call back function
MyRadioLibrary::loop(); // listen for response events. When we get one fire call back.
Now the question
When I call the SendEvent function I am passing 2 things (1) an integer and (2) a pointer to a function that is the call back. The integer (1) is passed as value and that will be part of the stack of the SendEvent function. The pointer (2) will be stored on an array of pointers. But what about the lambda function? where will that be stored? Instead of using a lambda function should I declare those functions in global scope and pass the global function instead of a lambda? Will I run the risk of the pointer (2) pointing to a function that no longer exists if I use this way of coding?
Tono Nam
  • 966
  • 22
Your functions won't cease to exist. All of the code in your compiled and linked code image gets loaded into code-memory (Flash) and it stays there throughout the run, through resets, and through power-cycles, until another image is loaded over it.
Are you confusing pointers to functions with pointers to a function's local variables which occupy RAM memory, specifically within the function's stack-frame which is transient, being created and "destroyed" as the function gets called and returns - and successive stack-frames won't necessarily be created in the same place.
JRobert
  • 15,407
