I am doing a project and using NodeMCU ESP8266. My project includes sensors for UART, I2C and 4 interrupts. I need to read the data from these sensors and get these data via microUSB in real time. While reading about NodeMCU ESP8266 there are so many points that came across and have certain questions.
  1. Do flash uses GPIO6-11 all the time? Can we use any of these pins for our purpose? What if someone needs an SPI communication, as these pins are locked by flash.
  2. Can I use GPIO-0 (flash pin) for my purpose, as after flashing the MCU the pin will get free.
  3. Do CP2102 uses GPIO 1 and GPIO 3? Can I use these pins for my purpose? (Given I need the data via USB, which I guess comes through CP2102)
  4. Can I receive the sensor data from SoftUART bus and get that data to my computer via USB?
I am confused from the articles given over internet. I request if anyone knows how these work, please explain.
Thank you
It is Quad SPI. The CS pins for this SPI interface are controlled by low level code. So you can't use this pins as GPIO and they have limited use as SPI too. If the flash access is set to normal SPI, the two pins io 9 and io 10 used for quad mode can be used as GPIO.
You can use io 0 as GPIO. Only make sure it is HIGH at boot. The bootloader reads it at boot to determine if it should go to flashing mode. Other boot config pins are io 2, it must be HIGH at boot and io 15, which must be LOW at boot.
Pins io 1 and io 3 are wired to the USB chip and used for Serial. They can be used as io pins, if you don't need Serial communication over them. Serial in esp8266 Arduino can be swapped to different set of pins for use with a serial device. For output printing you can use Serial1 which has only TX. To relay this output to USB bridge io 2 (Serial1 TX) to io 4 (Serial TX wired to USB).
You can use SoftwareSerail or the trick mentioned above.
see NodeMCU pins
Juraj
  • 18,264
  • 49
