I have configured a hc-05 bluetooth module as master and a hc-06 module as slave an since the LED on the hc-05 is blinking in a 2s delay they should be paired but no matter what I do I can't send data between the two Arduinos.
Here is the code for the slave (I use the example code from the EasyTransfer module github repo: https://github.com/madsci1016/Arduino-EasyTransfer):
    #include <Wire.h>
    #include <EasyTransferI2C.h>
//create object
EasyTransferI2C ET;
struct RECEIVE_DATA_STRUCTURE{
  //put your variable definitions here for the data you want to receive
  //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
  int16_t blinks;
  int16_t pause;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE mydata;
//define slave i2c address
#define I2C_SLAVE_ADDRESS 9
void setup(){
  Wire.begin(I2C_SLAVE_ADDRESS);
  //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
  ET.begin(details(mydata), &amp;Wire);
  //define handler function on receiving data
  Wire.onReceive(receive);
  pinMode(13, OUTPUT);
  //check and see if a data packet has come in.
  if(ET.receiveData()){
    //this is how you access the variables. [name of the group].[variable name]
    //since we have data, we will blink it out.
    for(int i = mydata.blinks; i&gt;0; i--){
      digitalWrite(13, HIGH);
      delay(mydata.pause * 100);
      digitalWrite(13, LOW);
void receive(int numBytes)
here is the code for the master:
#include <Wire.h>
//create object EasyTransferI2C ET;
struct SEND_DATA_STRUCTURE{ //put your variable definitions here for the data you want to send //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO int16_t blinks; int16_t pause; };
//give a name to the group of data SEND_DATA_STRUCTURE mydata;
//define slave i2c address #define I2C_SLAVE_ADDRESS 9
void setup(){ Wire.begin(); //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc. ET.begin(details(mydata), &Wire);
randomSeed(analogRead(0));
void loop(){ //this is how you access the variables. [name of the group].[variable name] mydata.blinks = random(5); mydata.pause = random(5); //send the data ET.sendData(I2C_SLAVE_ADDRESS);
//Just for fun, we will blink it out too for(int i = mydata.blinks; i>0; i--){ digitalWrite(13, HIGH); delay(mydata.pause * 100); digitalWrite(13, LOW); delay(mydata.pause * 100); }
delay(5000); }
Dennis L
