I am new to Arduino which I got only this week for my project which sends sms from my windows application.
I have Arduino Uno R3 and GPRS Shield (Simcom) Sim900 (S2-1040S-Z0912)
I am currently following this guide > https://educ8s.tv/arduino-gsm-shield/
As of the moment I have problem connecting the Sim900 to Arduino (I think Arduino cannot detect Sim900). The Arduino is working properly as my PC detected it. Also I confirm that the SIM900 is working properly as I can call the Sim inside and it is ringing (also the led on the device is blinking almost every 3 secs or so)
I found this, but I'm planning to use USB powered only as I only need the SMS feature so I am stacking the SIM900 on top of the Arduino. How to communicate the Arduino board with SIM900?
I am using this library http://www.tinyosshop.com/datasheet/GSM_GPRS_GPS_Shield_GSMSHIELD.rar
and below is the sketch:
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
int numdata; boolean started=false; char smsbuffer[160]; char n[20];
char sms_position; char phone_number[20]; char sms_text[100]; int i;
void setup() { Serial.begin(9600);
if (gsm.begin(9600))
    Serial.println(&quot;\nstatus=READY&quot;);
    started=true;
else
    Serial.println(&quot;\nstatus=IDLE&quot;);
if(started)
    if (sms.SendSMS(&quot;214&quot;, &quot;?15001&quot;))
      Serial.println(&quot;\nSMS sent OK.&quot;);
    else
      Serial.println(&quot;\nError sending SMS.&quot;);
void loop() { if(started) { sms_position=sms.IsSMSPresent(SMS_UNREAD); if (sms_position) { Serial.print("SMS postion:"); Serial.println(sms_position,DEC); sms.GetSMS(sms_position, phone_number, sms_text, 100); Serial.println(phone_number); Serial.println(sms_text); }
delay(2000); } };
and here is the output
Trying to force the baud-rate to 9600
1200 2400 4800 9600 19200 38400 57600 115200 ERROR: SIM900 doesn't answer. Check power and serial pins in GSM.cpp
status=IDLE
What I have tried so far:
I tried the sketch with SoftwareSerial mySerial(7, 8); and SoftwareSerial mySerial(9, 10) which i found on other tutorials but didn't work.
I tried modifying GSM.cpp and modify the value of _GSM_TXPIN_ and _GSM_RXPIN_ to 7, 8 and 9, 10 but didn't work.
Found that the pin on my Arduino is RX=0 and TX=1, and SIM900 is TX=0 and RX=1, tried the SoftwareSerial code above but with 0, 1 and GSM.cpp with 0, 1 but still not working.
I am currently still trying every other sketch i find on the internet but nothing works.
EDIT: This is the link for the module i bought https://www.lazada.com.ph/products/sim900-gsm-shield-i267689740-s379728457.html?mp=1
I cant find the link for the datasheet of this specific module so I will try to include the picture of the module
SIM900 Bottom
SIM900 Top
Henry
After many trials, I found the solution to my problem, thanks to @Majenko for mentioning the jumpers.
I am still stacking the SIM900 module on top of Arduino.
Switching the jumpers from D1 and D0 to D8 and D7 solved the problem (see green square on the pic)
I don't know why it needs to be on D8 and D7 since on board it says TX=0 and RX=1 and vise-versa for Arduino
JUMPERS
Then used the below sketch from this tutorial > https://lastminuteengineers.com/sim900-gsm-shield-arduino-tutorial/
//Create software serial object to communicate with SIM900 SoftwareSerial mySerial(7, 8); //SIM900 Tx & Rx is connected to Arduino #7 & #8
void setup() { //Begin serial communication with Arduino and Arduino IDE (Serial Monitor) Serial.begin(9600);
//Begin serial communication with Arduino and SIM900 mySerial.begin(9600);
Serial.println("Initializing..."); delay(1000);
mySerial.println("AT"); //Handshaking with SIM900 updateSerial(); mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best updateSerial(); mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged updateSerial(); mySerial.println("AT+CREG?"); //Check whether it has registered in the network updateSerial(); }
void loop() { updateSerial(); }
void updateSerial() { delay(500); while (Serial.available()) { mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port } while(mySerial.available()) { Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port } }
With this, it displays correct output on serial monitor based on the tutorial and I can confirm that its working as well on my windows form application as it can send sms from the application.
Henry
